Late turbo front on early n/a?
+2
jayman1869
6 posters
Anyone on here ever put a late model turbo front bumper on a early N/A car. I want to have that clean looking front to include the slit to help the LS1 breath once she's in.
What all is entailed with the swap. Complete fender and bumper swaps or just the bumper?
jayman1869- Posts : 29
Re: Late turbo front on early n/a?
Ive done it but with the Kokeln GTR bumper and on an 87. I had to change to turbo front fenders and buy a turbo bumper support. I think thats about it besides maybe the headlight sail panels but Ive never confirmed that; I have TPC fixed headlights.
This may not help much but....it can and has been done!
Headlights shouldnt be an issue because I too will be doing the fixed headlight conversion.
Thanks for the info.
i have done many . you need the fenders and the bumper along with the hardwere for said parts . other than that it's just a matter of removing the old and bolting on the later parts . about a 6 to 8 hour job . to a newbee add 3 or 4 more hours .
962porsche- Posts : 135
962porsche wrote:i have done many .....about a 6 to 8 hour job . to a newbee add 3 or 4 more hours .
OUCH!!!!
hahaha
If you are mechanically inclined you can convert your N/A fenders, you can trim N/A fenders to match a turbo bumper cover. I've done this conversion by making a card board template then trimming the fenders with a cut off wheel. If you cut carefully you will only have to dress the cut ends, you could also roll the ends but this will cause the paint to crack.
To support the turbo front end, you will need the following parts;
-Turbo Bumper Shocks
-Turbo Bumper Cover support (aluminum bar that mounts on bumper shocks)
-Turbo Head Light Covers
-Turbo Nose Panel
-Some rewiring to support turbo fog and driving lights
There are pictures gallery of the conversion in my gallery (pormgb), the right side still needs some work because the fender was damaged and repaired.
-Turbo Nose Panel
pormgb- Posts : 186
sweet.. I'll check it out.
I want to swap it over so it gives it a cleaner look as well as when I put in this LS1, I can have the filter go straight and that way I can have hair flow straight through the bumper to the filter!
i just got the turbo s front swap with lindsey vented nose, bolted right up mostly besides a couple brackets for the front bumper and fender since it was an 87 na
luginbuhlj- Posts : 24
luginbuhlj wrote:i just got the turbo s front swap with lindsey vented nose, bolted right up mostly besides a couple brackets for the front bumper and fender since it was an 87 na
This is what Eric needs to do once he has cloned himself.
gamman- Posts : 112
