» LS3 Exhaust
Today at 3:14 pm by Porsche951toLS3
Today at 2:26 pm by 944-LT1
» 1984 Gen IV 5.3 Swap
Today at 2:03 pm by superman22x
» alignment specs
Today at 1:44 pm by sharkey
» 86` 944 turbo project
Yesterday at 8:00 pm by jpkinerk
» Question about 964 transmission into 924s/944
Yesterday at 1:52 pm by Hamr20
Yesterday at 12:36 pm by sharkey
» For sale $150 Griffin for LS1 LS Radiator swap
Yesterday at 12:33 am by jshprd
» Vented Nose Panel
Wed Jan 17, 2018 4:00 pm by Hotrodz of Dallas
» Fitech vs GM PCM
Wed Jan 17, 2018 11:31 am by Hotrodz of Dallas
January 2018
Turn signal problem.
Post  fliermike45 on Wed Nov 16, 2011 4:02 pm
I just hooked up my front lights after re-fitting the nose. First problem was a blown fuse in the Left Side park circuit. Parking light circuit(s) work OK from the turn signal lever and from sidelight switch.
Now I can't get either left or right turn signals to work with the Ignition on. Fuses all checked.
Question is: What circuit was disturbed/broken when taking out the 944 engine and computer? Any thoughts and ideas would be welcome, thanks.
Problem solved.
Post  fliermike45 on Wed Nov 16, 2011 5:52 pm
Problem solved......After carefully tracing through the wiring schematic I found that the lines to the bulbs pass through the Hazard Switch.
I had removed the Clock panel that also holds the Hazard Switch.......Duh!
Re: Turn signal problem.
Post  acorad on Wed Nov 16, 2011 7:04 pm
while you're messing with it, how hard would it be to wire the turn signals into the ignition such that they only work when the engine's running?
I drained my battery twice by accidentally leaving the turn signal stalk in the "on" position when parking my car, which means the turn signal light stays on after I parked and walked away...doh!
Post  944convert on Wed Nov 16, 2011 7:27 pm
That's done with 12 Volts from key switch (P) in the "Off" position. It's a green EDIT...oops NO IT IS A GREY wire that powers the Right or Left turn signal (non-flashing) when car is parked (turned off) and the switch stalk remains either or Up or Down.
You can probably just snip and tape the green EDIT: GREY (not green) wire.
Last edited by 944convert on Tue Nov 19, 2013 12:25 pm; edited 1 time in total (Reason for editing : GR is the abbrevation for GREY not green. GN is for green...sorry.)
Green wire
Post  fliermike45 on Wed Nov 16, 2011 7:34 pm
Just checked the schematic, I confirm that it's the green wire.
Post  acorad on Wed Nov 16, 2011 11:23 pm
How great is this forum.
Post  944convert on Thu Nov 17, 2011 7:28 am
And before anyone asks...it’s a German vehicle traffic regulation…their version of parking lights can also operate on either the left or the right side of the car only.
It’s used when parking on dark narrow streets to provide a ‘parked-vehicle’ warning to approaching drivers while using only half the battery power of all 4 parking lights because the curb side lights are not lit.
Parking lights
Post  fliermike45 on Thu Nov 17, 2011 7:51 am
Confirming what was said earlier, yes if you put the turn signal on left or right with the ignition and main light switch both off you get the appropriate side lights ALSO when you open the driver's door the gong (chime) sounds off to warn you.
Post  acorad on Thu Nov 17, 2011 3:01 pm
fliermike45 wrote:Confirming what was said earlier, yes if you put the turn signal on left or right with the ignition and main light switch both off you get the appropriate side lights ALSO when you open the driver's door the gong (chime) sounds off to warn you.
My door chime always goes off when I open the door. Kind of annoying, actually.
Post  Arthropraxis on Thu Nov 17, 2011 5:43 pm
It goes off with the key out and the turn stalk in the correct position? I had that problem. It was fixed by twisting the assembly that attaches to the steering rack down on the left, slightly. The turn signal was apparently getting impinged.
Post  acorad on Thu Nov 17, 2011 5:56 pm
Arthropraxis wrote:It goes off with the key out and the turn stalk in the correct position? I had that problem. It was fixed by twisting the assembly that attaches to the steering rack down on the left, slightly. The turn signal was apparently getting impinged.
Huh. I was just getting ready to pull the chime itself out. I'll try your method first.
Post  acorad on Tue Nov 19, 2013 10:52 am
Hi all, I know it's been a while, but I don't see a green wire coming from the ignition cylinder. But there is a green wire (and a red wire) coming from a small white plastic plug that looks like it's plugged into the steering wheel side of the ignition cylinder, is this the green wire to cut?
GREY WIRE not green
Post  944convert on Tue Nov 19, 2013 12:34 pm
I just looked at the switch then the schematic...my bad...GR stands for grey...cut the GREY wire.
That 2 wire white plastic plug on the mounting bracket will supply +12 volts on the GREEN wire whenever the key is turned all the way off but not yet removed...maybe to allow the radio to stay on.
Post  acorad on Tue Nov 19, 2013 12:38 pm
944convert wrote:I just looked at the switch then the schematic...my bad...GR stands for grey...cut the GREY wire.
Awesome, thanks!
Post  944convert on Tue Nov 19, 2013 12:52 pm
Good thing I don't work in the bomb squad Razz
Post  acorad on Tue Nov 19, 2013 1:00 pm
Ha, or surgery!
Post  acorad on Mon Dec 16, 2013 6:02 pm
Well I finally got around to doing this. It took only a couple minutes and now no more of that annoying "feechure!"
