Shift linkage adjustment
After all of the changes in motor and transmission position there seems to be a little binding in the linkage. Did anyone else need to adjust the linkage? I am going to do a fix for the slop side to side in the shifter and check the plastic cup at the bottom while I am at it.
Re: Shift linkage adjustment
While your in there just throw a short shift kit in
skywalker01- Posts : 477
Adjusting shifter
Good article here:
http://www.clarks-garage.com/shop-manual/trans-07.htm
Thanks, for the link. I may go with a short shift kit if it isn't coming from the shifter. I should have looked at the linkage bushing this weekend when I was changing my trans fluid.
Shifter
I fitted a short shifter kit and had to do the adjustment as listed in the thread. The short arm in the mechanism (on the gearbox) has a slot and to get my shift lever vertical I had the adjuster to the end of the slot.
What brand short shifter did you get? If I get one it will be from Xschop.
I got a Schroth kit - works fine, lasts long time.
Me too.skywalker01 wrote:I got a Schroth kit - works fine, lasts long time.
Shifter
Same here.....Rob had not developed his when I purchased, From my experiences with other products by Rob I would choose that route.
How much lateral play should there be in the bushing at the transmission linkage? It feels like a couple of millimeters if I grab the intermediate shaft and move it side to side.
Installed my SSK from Xschop today. It took the slop out and the throw is great. So, to answer my own question, there should be no lateral movement at the rear linkage bushing.
» custom torque tubes or ideas to mount a 930 transaxle
» Short Shift Kit
» Short Shift Kit
