Turbo Transmission
Turbo Transmission
Hello all...I have a Turbo transmission that I purchased for my conversion. How would I know the condition its in? It seems to be OK. Also is their a write up on how to swap the fifth gear from my n/a(I hear that it should be done). Is there a way to clean it up before I put it in?
Thanks all.
Thanks all.
Red944ls1- Posts : 98
Re: Turbo Transmission
Here's one of many links to the 5th gear swap articles:
As for is it good, I'd look for obvious items, play in the input/output shafts, I'd expect the tolerances to check are in the Porsche manuals.
Cleaning it up, your choice of degreasers and a stiff brush. I find the citrus ones work pretty well, easier on you too.
Good luck with your project!
Thanks a bunch for all your help thus far!!!!
87-944S wrote:Here's one of many links to the 5th gear swap articles:
That's wild . . . . the guy is using most of my pictures, and in some instances, using my exact description from the article I wrote back in '08. No mention of source . . . . where's the luv
Here is the original:
Merry Christmas everyone !!!!
marc a- Posts : 170
» Where to locate a turbo LSD transmission
» Wanted: Turbo Transmission
» 944 Turbo Transmission 5P code
