Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
I need to replace my radiator
Page 3 of 3 Previous  1, 2, 3
Re: I need to replace my radiator
Post  acorad on Thu Oct 11, 2012 5:05 pm
Admin wrote:Lower is a 99' Firebird and the upper will need to be spliced
Admin, the 99 firebird lower hose is just barely too small to go on the 951 rad outlet. Is there some trick/mod that I need to do to make it work?
Post  Admin on Fri Oct 12, 2012 8:03 am
No tricks, just slide it on. That's what I use on all the cars that we convert.
Post  acorad on Fri Oct 12, 2012 8:40 am
Admin wrote:No tricks, just slide it on. That's what I use on all the cars that we convert.
Maybe I need to get the hose from the dealer instead of Pep Boys?
Post  rooster on Fri Oct 12, 2012 9:04 am
I used a 99 Firebird hose from Napa or Autozone, can't remember, but it worked fine. I do remember having to cut it for length where it goes on to the radiator to make it fit. Have you cut yours already?
rooster
Post  acorad on Fri Oct 12, 2012 12:55 pm
rooster wrote:I used a 99 Firebird hose from Napa or Autozone, can't remember, but it worked fine. I do remember having to cut it for length where it goes on to the radiator to make it fit. Have you cut yours already?
I didn't cut it yet because I can't get it on!
Post  acorad on Fri Oct 12, 2012 1:35 pm
Oops, just noticed that one end of the hose is bigger than the other. Doh!
PS: However the small end of the hose won't fit on the water neck either...
Post  acorad on Fri Oct 12, 2012 3:00 pm
Well, I'm stuck.
I went to Napa to check their products and and their 99 Firebird lower rad hose and water neck are the same as the Pep Boys ones that I have.
The lip on the water neck is slightly larger diameter than the lip on the 952 rad outlet, but the small end of the 99 Firebird hose doesn't fit over either one, so I'm stuck.
Any ideas? Can the hose end be stretched?
Post  944convert on Fri Oct 12, 2012 3:11 pm
try a pot of boiling water & stick the end in it
Post  acorad on Fri Oct 12, 2012 6:28 pm
944convert wrote:try a pot of boiling water & stick the end in it
Thanks, a heat gun did the trick! I plugged in the P cooling fan wiring and only the pass side fan comes on, and only on high, and at 203F. My relay is bad?
