Boxster Rear Calipers
Page 1 of 2
Page 1 of 2 • 1, 2
I have needed some rear calipers to match my Cayenne fronts (which are awesome, by the way), and I believe this is the best way. The calipers are ordinary Boxster calipers. I paid $70 on eBay, but there are cheaper options at local scrapyards. I simply made these on my Clausing drill press with layout fluid and a nice 6" rule. I can post dimensions if anyone is interested, or I'd be happy to make them. These pictures are with NA rotors, but the calipers would be best fitted with turbo rotors. These rotors are junk anyway, so I plan to get Turbo rotors soon.
The bolts are not the ones I would use, they were just what I have around. My stock of M12 bolts is lacking... And yes, the caliper is upside down, it's just this side of the car was more available for fitting and I only have one caliper so far.
superman22x- Posts : 272
Re: Boxster Rear Calipers
You can post the dimensions of the adapter bracket ?
Thank you
Thank you
AMFCSL- Posts : 12
Yep, I'll try and post it within the next couple days.
If you can make me a pair or provide dimensions I would appreciate it. I just bought a 1987 944 shell (with a new paint job/Maraschino cherry).I have to make my brake decision and yours sounds pretty good!
Thanks in advance,
Barry
Thanks in advance,
Barry
Fubar- Posts : 9
I apologize I haven't posted this yet... My computer went down. Bad RAM module seems to be the root cause. Windows install was corrupted. It's back up on a fresh install. I still need to reinstall NX to create the drawing. I may have exported a dimensioned draft. I'll try and check this weekend. I can make them if anyone wants too.
do you have any news for dimensions?
thank you so much
thank you so much
AMFCSL- Posts : 12
Sorry, I'm still having computer struggles. I hope to fix it this weekend...
Finally got the computer running again. Thanks to microcenter for allowing me to exchange my 2 bad sticks of ram yesterday.
EDIT: See post further down, made some updates to the drawing.
Adaptors
Hi, I'd be interested in an adaptor set for both front and rear calipers. I have a 944 race car that we are building into an endurance racer for WRL/AER. It will have an aluminum 5.3. I have a set of Boxster S calipers for the front that I'd like to mount to the turbo spindles. I'd also need a set of brackets for the rear and I'll pick up a set of boxster S rear calipers. It would be great if it stopped as well as it's going to go. I can be reached via email at cscowden@gmail.com.
Chris
Chris
cscowden- Posts : 4
I made some changes to my drawing. If you run NA rotors (289mmx20mm), you can run base boxster rear calipers. See the drawing below.
The base calipers are not wide enough to run turbo rotors (299mmx24mm). You need Boxster S calipers for this. I believe these are the same caliper castings as the rears and base fronts, just different size pistons and made for a thicker (24mm) rotor.
For the fronts, you would use basically the second drawing, but there is a slightly different offset. I'm working on a drawing for Boxster S fronts with Turbo rotors for Chris still.
Alright, I found an old XSchop drawing that gave me the distance I needed. This should be the drawing for the fronts using Boxster S calipers mounted to Turbo rotors. I'll make a test piece to send to Chris to verify for sure though.
hey man - Anyway you can go and edit the size of your pictures so we can see the entire thing?
LStuner- Posts : 32
I AM TO REALIZE A PROTOTYPE FOR THE 944 TURBO S NEXT MEASUREMENTS
EXACT
EXACT
AMFCSL- Posts : 12
Those are Boxster S calipers on Turbo fronts?
I think you can click the picture, or right click and "view image" to see the full picture.
FYI, the hardest part is drilling and tapping the M12x1.5 holes perfectly straight. On one set, I attempted to hand tap the holes after drilling them on my mill, and the bolts would not thread in nicely. I had to use a tap center in the mill to get the bolts to go in smoothly.
Awesome! 996 are the same as Boxster S. Let me know if you run into problems mounting them. I haven't made my set for Chris yet.
I have realized I made a stupid mistake. On the dimensions I give, there is one 12mm hole that is 7mm from an edge, and another 12mm hole that is 8mm from an edge. This won't work. I made these dimensions 9.5mm in my parts for Chris. Hoping everything fits. If not, I'll have to figure something out.
HERE THE PROTOTYPE IN WOOD WITH THE BAR ALU 6082 4X4 CM THE DEFINITIVE SHAPE MUST BE THIS AT LEAST WITH A TURBO S WITH ABS AND OPTIONAL 030. THE MEASUREMENTS ARE NOT DEFINITIVE MISSING SOME MM
AMFCSL- Posts : 12
You have Turbo S M030 spindles? Those are radial mount not axial mount.
Page 1 of 2 • 1, 2
Page 1 of 2
