Dual headlight motor conversion
+9
aixgelo78
pormgb
laptop_geek
944-v8
golfduke
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Dual headlight motor conversion
This is what you need...
911-615-109-01
Multi-purpose 5-pin relay
I bought a cheapo one from Pelican; cost is $14.
I also posted some info from when i hooked up my 914 motor which you may find helpful.
https://944hybrids.forumotion.com/t1680p150-techno-duck-s-ls1-conversion#27402
https://944hybrids.forumotion.com/t1680p195-techno-duck-s-ls1-conversion#28008
911-615-109-01
Techno Duck- Posts : 447
Thank you! Answer much appreciated-
Jasonscottw- Posts : 125
Ok, another question (or three):
I'm using 914 motors on both side. Do I still need to use the diodes?
If so, which wire do the diodes go on? 12v+? Triggers?
And do I just run/splice wires over the second motor in parallel?
Thanks-
Thanks-
You will probably still need the diodes as the 2nd motor piggy backs off the wiring.
I am not sure how the motors are wired on the 914 but i suspect each motor has its own circuit, they dont piggy back so they dont need them.
The diodes have to go on the two trigger wires, in the direction of the 914 headlight motor.
The wiring diagram here shows diodes on both of the command lines at both of the motors. It looks like they're external to the motor housing by the way they're drawn, but mine don't have any, so I'm thinking they must be part of the car-side harness. Both motors are tied together on the same command circuits.
haroldk- Posts : 140
Ok, so I got both motors cycling up and down when manually connecting the appropriate trigger wires (with diodes), but the motors do nothing when all wired up and I turn on the headlight switch.
Any ideas RE what I'm doing wrong?
At the moment the only thing that is wired up for this test phase is the motors- the headlights and other front end lighting are not hooked up yet, and I only have one 914 relay (I've been switching it back and forth to test). Don't think any of those things would affect the motor(s) function, but . . . ?
Have you checked the fuse?
Yup
Don't think it is the switch either, since it used to work fine.
When I power the headlights up with the trigger wire, they do a full cycle-
They don't stay in the up position. They go up and back down.
Is that what they should be doing? I was thinking that the switch would keep them
"Up"/in a energized state, but maybe that is a flawed assumption-
Totally stumped-
Totally stumped-
Do you have pin 87a on the relay grounded? It's possible they're just overshooting and then completing the cycle.
The diodes are used to prevent the issue you mention, returning to closed. Picture or diagram of your wiring?
Bringing this back up...sorry
Where and how do you cut the headlight bar? I have the 914 motor sitting on the work bench.
Thanks if there are any pics too!
rdanford- Posts : 96
rdanford wrote:Bringing this back up...sorry
1 page back, you can see where the bar has been cut off of the pivot.
https://944hybrids.forumotion.com/t14-dual-headlight-motor-conversion#19931
Page 2 of 2 • 1, 2
» were to buy the sbc motor conversion kit
» For sale Wilwood dual MC balance bar and Dual MC firewall mount
» Xschop's 5.3 LM7 build
Page 2 of 2
Today at 6:58 am by Rob44
Today at 12:47 am by sharkey
