» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
XSchop 1-off V8 install kit
Post  xschop on Sun Oct 16, 2011 4:16 pm
$1650 shipped to any US-48
Everything needed for a basic swap minus the oil-pan (I suggest getting TPC's) as This kit uses TPC's AC-compatible uprights and allows maximum steering rack clearance. The X-member is precision line-bored at the control arms for exact 3/4" drop. I guaranteed your hood will close even with a power steering rack. 3/4" X-member spacers and 3/4" longer X-member bolts. 3/4" Sway bar spacers. 3/4" bump-steer tie-rod drop blocks. Bolt-on Modded 13/16" Wilwood MC and custom adjustable pushrod adapter. Modded C5 throwout bearing with -3an lines included to fit the C5 Bellhousing adapter with TT mounting hardware included. Your chioice of LS or LT/SBC pilot bearing adapter and new pilot bearing. 1/4" thick 2000 series alloy brake MC adapter for factory 944 MC and custom adjustable pushrod adapter. And Last but not least a custom Stainless steel steering shaft with brand new Borgeson U-joints made for the 3/4" X-member drop. It is adjustable due to the Double D ends.....
Re: XSchop 1-off V8 install kit
Post  xschop on Sun Oct 16, 2011 8:32 pm
Just remembered, price includes one of my Billet/poly trans mounts as well... I'll have a batch done in 2 more weeks....
Kit
Post  zeusrotty on Sun Oct 16, 2011 8:48 pm
So with this kit can I have hydrobosted brakes?
zeusrotty
Post  xschop on Sun Oct 16, 2011 9:09 pm
Sure, and if someone supplies the pushrod dims I'll make one for it and cut another custom firewall plate as well Wink
Also not in the pic is a brand new set of the male threaded outer tie-rods that are part of the bump-steer mod, just re-use your inner power steering tie-rods....
Post  robstah on Mon Oct 17, 2011 7:00 pm
Damn, I wish this was available when I bought all my stuff. Sad
Post  xschop on Mon Oct 17, 2011 7:56 pm
Someone asked and I'll ship everything for $1450 without the trans mount.
Post  xschop on Tue Oct 18, 2011 6:19 am
Sold
Can this kit be used for Ford 5.0L coyote swap?
Post  liqtor on Sun Nov 03, 2013 12:22 am
Looking for a mounting kit to get my project started with the 5.0L coyote engine from ford I have not found anyone with a specific 944->coyote mounting kit and wondered if that would work; if so can you get or make another? Finally if it would not work can you make a kit that WOULD work?
kind regards
Lloyd
liqtor
Post  Bankroll Bullies on Wed Feb 19, 2014 10:10 am
PM me if you make another kit soon. If it has everything o need for the swap I will buy that in a min. I don't see headers on there. So that means I will still need headers and a oil pan right?
Bankroll Bullies
http://www.bankrollbullies.com
Post  xschop on Thu Feb 20, 2014 6:10 am
Get TPC's swap kit and I'll send you an adjustable trans mount. His kit is quality and he stands behind his work. With 1\2" Xmember spacers, throttle body trim, and the Transmount, your hood should clear without touching it.
