» Transaxle rebuild
Today at 8:51 pm by yamamtx
Today at 8:27 pm by matt889
» Hello, Gentlemen.
Today at 7:43 pm by rawr
Today at 7:37 pm by Porsche951toLS3
Today at 7:17 pm by Porsche951toLS3
» alignment specs
Today at 12:53 am by sharkey
LT1 Flywheel
LT1 Flywheel
Post  quarterflash on Wed Oct 12, 2011 4:03 pm
Hi
I am about to order a flywheel for my LT1 / 944conversion. I know that I need 153 teeth but my supplier has asked if the clutch will be push or pull? I will be using an old conversion kit supplied by Renegade Hybrids about 8years ago.
Can someone advise?
Thanx
Q
quarterflash
http://porschevy.co.uk/
Re: LT1 Flywheel
Post  944-LT1 on Wed Oct 12, 2011 11:32 pm
Push. The RH LT bellhousings had the corvette slave cylinder mounted on the bellhousing and pushing the fork which pushed the PP fingers in.
