87-944S First Drive!
+4
8 posters
Here it is coming out of the garage and first drive down the street! This vehicle has been up on jacks for the past 9 years or so. Needs paint and interior work, but felt solid, all this work is paying off finally.
Re: 87-944S First Drive!
Congratulations. That has to be satisfying.
Thanks, it is, just kicking myself for taking so long! But in my defense, I replaced everything that I could in the suspension, I feel like I am starting out with a new car. Now I need to step it up and get it street legal, and give Skywalker some competition in the local autocrosses.
Congrats. Did you wind up keeping the hydroboost? I like the see-thru hood too. I wonder how much it weighs?
I dont know if its the video or is that PS pump just really loud? Got fluid?
Congrats regardless!
Congrats...
Congratulations...
Curious, what's the metalic ringing noise?
Excellent!
acorad- Posts : 697
No Hydroboost, the dual M/C setup with Wilwood M/Cs and balance bar setup. Not sure what the noise is, I do have P/S fluid, I will have to investigate, hopefully nothing serious! I'm fairly certain I may have an exhuast leak at one of the collectors, the bolts were a pain to install. Just glad it didn't go up in smoke and I was finally able to run it long enough for the engine to cycle the fans and keep an eye on operating temps and pressures.
As for the hood, I don't need no stinking hood! It made for a ot of stares when I drove around, as well as the exhuast note!
I don't know about the noise - I have noticed that hand-held cameras tend to amplify higher frequency sounds. You may be chasing a ghost. Looking forward to seeing you out at the course at the end of October!
skywalker01- Posts : 477
Without a hood means no need for the windshield washer tank!
Did not know about cameras exaggerating high freq. noises. Might be nothing then.
Just got back from a biz trip, will fire it up again this weekend and check for noises!
I know it was just a short trip, but, how was the braking feel? Exhaust loudness and how do you have your exhaust set up?
Brakes are not complete, the rear hydraulics are not hooked up, so I had very minimal brakes. I won't be able to get a good feel until I finish them up and adjust bias. Exhaust has a very nce tone, but bit too loud for me, so I have a Flowmaster resonator that will go in. Exhaust is 3 inch from the collectors to a Y pipe, high flow cat, and a Flowmaster 50 series SS muffler, with Magnaflow 5 inch baffled oval tip, all pipes are 3 inch.
