Transmission Brace.
Transmission Brace.
I saw pictures somewhere that someone made a brace to shore up the tranmission from all the movement the crappy late mounts allow. Anyone have any clue, or have seen this?
Dawgz83948- Posts : 603
Re: Transmission Brace.
You mean xchop's? There's got to be a pic somewhere on here that you can find. Saw your ad on CL here in LA today. The last V8 944 sold down here was listed at 14K, iirc.
acorad- Posts : 697
Here is xchop's, it looks sweet: [You must be registered and logged in to see this link.]
acorad- Posts : 697
Transmission mount
Xschop's mount in place.
It was installed wrongly in this pic and I had to turn it around.
Thats the mount, somoeone made a brace that attaches to the side of the tranny keeping it from swaying side to side.
I have that side brace. Since I didn't install it, I don't know where it came from. I like the look of xchop's a whole lot better...
acorad- Posts : 697
The long solid rod brace transmits tranny gear noises/vibes and the trans can still rotate with the factory rubber mount installed anyways unless you're running solid or poly motor mounts.
