Yesterday at 10:58 pm by 948
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
Mystery brass fitting.
Post  fliermike45 on Fri Aug 26, 2011 4:07 pm
I filled my cooling system and have a minor drip from this brass fitting located in the crankase behind the starter motor. Can someone please identify it and what's it's use? Thanks.
Re: Mystery brass fitting.
Post  Arthropraxis on Fri Aug 26, 2011 5:10 pm
Block drain.
Block drain
Post  fliermike45 on Fri Aug 26, 2011 9:14 pm
Had a closer look this evening.
Main brass plug screwed into the block has a smaller plug (approx 3/8") screwed in to it.
This was loose and causing the drip.
Question is: The inner plug has two small nuts on the end, is this a transducer with a place for a terminal?
Last edited by fliermike45 on Fri Aug 26, 2011 9:15 pm; edited 1 time in total (Reason for editing : typo)
Post  944-LT1 on Sat Aug 27, 2011 6:32 am
Kinda looks like a temp sensor doesnt it?
Post  87-944S on Sat Aug 27, 2011 12:20 pm
Pretty wild looking starter, what kind is it?
Starter
Post  fliermike45 on Sat Aug 27, 2011 12:31 pm
Starter is a MSD
Starter
Post  fliermike45 on Thu Jan 19, 2012 8:37 am
And that starter was too large in diameter, would not allow the RH headers to fit tight to the head.
Swapped it out to a stock sized starter.
