» Headers, headers, HEADERS!
» Electric brakes
High powered 944 turbo V8 conversion Question
Post  SwissRacing on Wed Aug 24, 2011 8:46 pm
So I finally have my donor car, its 944 turbo.
I'm wondering what the hp/tq limit is for the 944 transmission. I plan on tracking this car a lot so it has to be reliable.
I'm thinking 500-600hp, is this doable?
thanks!
SwissRacing
Re: High powered 944 turbo V8 conversion Question
Post  expuppy on Thu Aug 25, 2011 6:35 pm
Its not an easy answer. I have 385-410 at the rear (dyno'd twice), and have sheared axle shafts and axle shaft bolts twice. Since that time, i have used caution launching the car from a dead stop and have had no issues on the street or on the track, 500-600 should be possible GIVEN you drive with the understanding that you are right on the edge of breaking something, especially in the lower gears. My codriver tried to win a beer bet that it would pull the front wheels off the ground and wound up with ball bearings dropping out of the cv's. Expensive beer.
expuppy
Post  87-944S on Thu Aug 25, 2011 6:52 pm
Check in on MichaelB's ride, he's supercharged, got to be well north of 500HP!
Post  v8carreragts on Thu Aug 25, 2011 9:47 pm
Here is a video of MichaelB at the drag strip.
Post  expuppy on Fri Aug 26, 2011 6:25 pm
Any idea what his time was? At 400hp, I turn a 12.8, 120 mph on street tires. These cars are so light, that hp and torque are not the limiting factor to success on the track. I purposely limited hp to increase reliablility of the drivetrain.
expuppy
Post  v8carreragts on Fri Aug 26, 2011 7:42 pm
I don't know what his time was. I think he has problems with tire spin. If you search videos you will find a short clip of him on the street and all he does is spin the tires. There are a few clips of his car after the supercharger.
This is why I am using a small displacement high RPM motor with a long duration cam. (302) The low end torque should be low enough so I should be able to get some traction.
