modding stock dash, boost pressure to oil temp
944Hybrids: 924/944/968 and 928 V8 Conversions :: Technical Stuff (other than motors) :: Interior upgrades
I was originally going for a racepac dash.. but figured hey, stock looks cool, then nobody will be the wiser on the underhood mod
has anyone got in detail pics, of the rear of turbo dash pcb? it would be cool to mod either the circut of boost gauge, to accept oil temp input, then "reprint" over the numbers with correct temp info. or replace the entire circutry/needle with a new gauge behind it, has anyone ever done something like this?
a951- Posts : 121
Re: modding stock dash, boost pressure to oil temp
There is a lot of good info in this post:
To be honest, it sounds like it would be easier to throw a gauge under the headunit. If you do end up doing this, I will applaud your efforts and might follow in your steps, especially if a new faceplate to the cluster surfaces.
robstah- Posts : 352
