» New 944 widebody & aero
Yesterday at 6:20 pm by scryfst
» ecotec swap
Yesterday at 6:16 pm by sharkey
» Wilwood MC on it's side
Yesterday at 6:09 pm by scryfst
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
» JP's LS1 Conversion
March 2018
Weight increase from LT1?
Post  NoTheOtherSparky on Wed Aug 03, 2011 8:39 pm
I'm planning an LT1 swap and maybe I'm not using search correctly but I can't seem to get any hits that will tell me how much weight I should expect to pick up due to the motor swap.
Looking to get to better than a 10 lb/hp number at the wheels, which I think should be pretty easy to do. Car will be more or less gutted as it'll be a track car. Probably won't be street legal.
Thanks for any tips, or if you have a suggestion of a better motor to use. Donor is an 87 944S.
Re: Weight increase from LT1?
Post  944-LT1 on Wed Aug 03, 2011 10:39 pm
These values differ all the time depending on options and accessories.... especially the 944 engine....due to the fluctuations in weight due to oil leaks Laughing Laughing
LT1 dressed = 460 lbs
LS6 dressed = 382 (w/o clutch) 420 (w/clutch)
944 dressed = 366 (dry w/o clutch) 410 (as running)
source: (LT/LS) GMperformance specifications, (944) I've weighed it personally
Post  v8carreragts on Wed Aug 10, 2011 10:51 pm
LT, your 944 dry weight is exactly the same as the official Porsche Spec book says! Your LT1 weight looks about correct as well. The Gen I (iron head) is 550# and the aluminum heads and intake are about 90# lighter.
