» LS6 Batwing Oil Pan
» LS3 Exhaust
» JP's LS1 Conversion
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
January 2018
lsd transmission
Page 2 of 2 Previous  1, 2
Re: lsd transmission
Post  Dawgz83948 on Tue Aug 02, 2011 9:45 am
spence wrote:Get the front and rear turbo sway bars too.
No, get the S2 front swaybar and turbo rear. IIRC the S2 front sway bar was slightly bigger.
Post  shwinny on Tue Aug 02, 2011 11:01 am
what is a s2. why so diffrent than a turbo or regular 944. i deffinatly will get the sway bars. Thats an excellant idea. and the spindles rotors and claipers will they go on my car also. He said the rears will bolt on but im not sure about the front. What about the fuel pump. The trans is listed on ebay. its the 944 turbo s2 trans no cooler and no lsd. it has 60k miles with the torque tube. I want to see what he has for rims also. I just want to do it right the first time. I appreciate all the feedback guys.
shwinny
Post  xschop on Tue Aug 02, 2011 11:06 am
Here's some feedback. Thanks to Tehone and a rainy day pictorial, a custom mount is doable.... This is the best pic that shows what needs to be done and the cross-bar can be a solid flat piece although arched and attached to the billet mounts. Again the late mount attaches to the flat side of the intermediate bracket and NOT the back side of the 2 "nipples"
Have given up on nipples
Post  fliermike45 on Tue Aug 02, 2011 7:27 pm
Here is my Xschop transmission mount for later cars correctly installed.
Post  shwinny on Thu Aug 04, 2011 10:13 am
I scored a set of 968 m030 sways also with the turbo s m030 rear sways. That should work
shwinny
Post  shwinny on Fri Aug 05, 2011 8:18 am
I just realized that i might be able to run the sway bar. doesnt the late model sway bars mount diffrent than the early sway bars to the contol arm. My sway bar is straddle mounted and it looks like the late models bolt through the control arm. Will a late model control arm fit my car.
shwinny
i meant not be able to.
shwinny
Post  shwinny on Sat Aug 06, 2011 7:50 pm
I now have a turbo trans/ torque tube with 60k miles. Turbo radiator/ fan assembly and support/ turbo steering wheel. Turbo rear calipers and rotors/ and now the xchop controll arms and early solid trans mounts, to go with my 968 m030 front and rear sway bars. I hope this helps finish my project. Thank you xshop I will keep you updated.
shwinny
Turbo trans
Post  Tehone on Sat Aug 06, 2011 11:13 pm
fliermike45 wrote:Just installed a LSD Turbo Trans in a NA 944, only mod required was to cut away some of the metal shield under the fuel tank to allow for oil cooler clearance. I also installed the NA 5th gear in the Turbo trans, real easy if you follow the published instructions.
FlierMike45,
What year of 944 did you put this Turbo trans in? I have an 84' that I am installing a 86' turbo trans into. I have wondered about the oiler cooler and you mentioned cutting some of the metal sheild under the fuel tank and I am not sure of what you cut out. I have not tried to install my tranny as of yet, still in the outside of car mock up.
If there is an issue with room for the oil cooler and there would be the need to remove the cooler what is needed to plug the holes in the tranny case?
Tehone
Mod to fue tank shield
Post  fliermike45 on Sun Aug 07, 2011 5:36 pm
Here is a picture of the mod I made to the fuel tank shield on my 88 car.
