C5 BH Slave
C5 BH Slave
Has anybody used this particular Throwout bearing? Oreilleys doesn't have the exact C5 bearings, but this one crosses with part# 15046288
Re: C5 BH Slave
I ran across a post on LS1tech where someone measured several different brands of the slave cylinders and they were all different. The implication is that it will change the size of the shim needed. You already know this. I thought it was interesting when researching the slave cylinder installation and measurement for the shim.
Re: C5 BH Slave
From all the posts I gathered that you should steer clear of any TO bearing casting that did not have AP D951004 on it as the others were Chinese. I'll check Oreilleys later. Just wondering if anyone else got this particular one. What's funny is I don't know the exact part# for the Delco C5 vette one that is in mine with the Camaro PP, but I do Know that there was Zero shimming done and still shifts perfectly. I read that the TO bearings were superceded with diff. part #'s
