» 1986 951 LS1 swap for sale
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptyYesterday at 7:39 pm by turbobob924
» 944 N/A Transmission
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptyYesterday at 11:50 am by sharkey
» FS: 88-89 Porsche 944 Turbo S LSD transmission code AOR w/ Cooler
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptyThu Aug 15, 2019 9:56 pm by Worryless
» What size oil cooler do I need?
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptyThu Aug 15, 2019 6:11 am by gwistrup
» LM7 C5 transaxle
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptySun Aug 11, 2019 11:26 pm by TCook
» 5.3 in 1988 with C5 Trans Questions
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptySat Aug 10, 2019 6:32 pm by sharkey
» Anyone who’s successfully put a C5 Torque tube in late 944
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptySat Aug 10, 2019 2:50 pm by Vortec88Porsche
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptySat Aug 10, 2019 2:39 pm by Vortec88Porsche
» A/C Question - WOT Switch?
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptyWed Aug 07, 2019 9:28 pm by superman22x
» V8 Swap Project Car Swap Out
lS1 CONVERSION COOLING QUESTIONS - Page 2 EmptyWed Aug 07, 2019 5:35 pm by DirtRocket
August 2019
Page 2 of 2 Previous  1, 2
lS1 CONVERSION COOLING QUESTIONS - Page 2 Empty Re: lS1 CONVERSION COOLING QUESTIONS
Post  Tony D59 on Wed Feb 24, 2016 11:28 am
will there cooling system work in a track only enviroment or will i have to add anything? from what i have read here hood vents are a must. what about the water pump? should i go with electric?
Tony D59
Post  docwyte on Wed Feb 24, 2016 11:34 am
Don't need an electric water pump.
Depends where you live, if you're running AC, are you doing sprints or enduros, etc.
I've had to add a secondary radiator but most people haven't had to do that. I do still have AC though, so having the condenser in front of the radiator doesn't help...
Post  Tony D59 on Wed Feb 24, 2016 11:36 am
No ac,enduro, full track build
Tony D59
Post  Tony D59 on Wed Feb 24, 2016 11:37 am
Do you know the model of radiator,
Tony D59
Post  docwyte on Wed Feb 24, 2016 12:11 pm
I'm running the Ron Davis, with a full fan shroud and 16" Spal fan that runs on high. I've got 4 hood vents, custom ducting and have added the auxiliary radiator from a 2004-2007 Audi S4.
Post  Tony D59 on Wed Feb 24, 2016 12:14 pm
And you track your car I'm guessing? We're did you put second rad and how do you vent/burp the system?
Tony D59
Post  docwyte on Wed Feb 24, 2016 12:41 pm
Yes, I track the car here in Colorado. So the bad combination of high ambient temps and thin air.
Radiator is V mounted on the passenger side, gets air ducted by the lower part of the grill and the fog light hole.
Gets burped normally, the overflow tank is still the highest part of the system.
Post  Tony D59 on Wed Feb 24, 2016 1:03 pm
any chance of getting some pictures of your setup?
Thx
Tony D59
Post  Tony D59 on Wed Feb 24, 2016 1:04 pm
I'm in the southern New York, good air but gets really hot in summer..
Tony D59
Post  Tony D59 on Wed Feb 24, 2016 1:05 pm
What size oil cooler are you running? Sorry for all the questions
Tony D59
Post  Admin on Thu Jul 14, 2016 1:39 pm
Just to add another source. We at TPC also offer a complete Dual Pass radiator with fans, shroud, bottom bracket, hoses, clamps, plumbed for stock GM and 944 and all needed HW.
Radiator - 789.99 - all accessories
Bracket - 124.99
Post  turbobob924 on Sun Jun 25, 2017 10:23 pm
late to post but interesting in learning more.
turbobob924
turbobob924
http://www.turbo924.com
Post  Admin on Thu Jun 29, 2017 10:55 pm
We have a new pricing on the Radiator.
TPC Dual Pass Radiator (LS1 Design) with hoses and brackets $599
Dual Fan Shroud. $149
We also offer a stock Turbo replacement with Hoses for $325.
Stock Fan Shroud. (Fit stock location) $149
Post  chris_f on Mon Feb 11, 2019 7:54 pm
What is the core thickness on the TPC radiator?
chris_f
