Fri Oct 19, 2018 2:47 pm by Hotrodz of Dallas
Fri Oct 19, 2018 9:22 am by robschwieb
» Fix for slow steering
Fri Oct 19, 2018 9:09 am by robstah
» Handling compared to a C5
Fri Oct 19, 2018 8:28 am by haroldk
» 944 LSD turbo/NA transaxle
Wed Oct 17, 2018 7:40 pm by x.l.r.8
» 944 with GM 5.3 / 4l60e / ford 8.8 rear end combo
Wed Oct 17, 2018 2:33 pm by Brownmaxr
» HOW TO DO AN ADVANCED SEARCH.
Sun Oct 14, 2018 10:26 pm by Guitmn
» light delete badge panel.
Sun Oct 14, 2018 8:58 pm by x.l.r.8
» Early / late suspension
Sat Oct 13, 2018 5:52 am by Guitmn
» Used Throw Out bearing
Fri Oct 12, 2018 9:18 pm by Admin
October 2018
lS1 CONVERSION COOLING QUESTIONS
Page 1 of 2 1, 2  Next
Post  GMMASTERTECH on Thu Jul 07, 2011 4:44 pm
Hey guys I'm in the early to mid stages of my conversion and interested in the best practices for the cooling system and exhaust. Which radiator and cooling fans really work best Question and whats the proven header/exhaust? My 944 is a 1986 n/a and the ls1 is a 5.7L from a 2001 camaro. My car is a "play time" street driver with air. The ls1 is installed with Erics Kit (all except) the headers which I'm still up in the air on. Thanks in advance for your experiences in these areas. As an Automobile technician I hate buying the wrong stuff and doing the job twice.
GMMASTERTECH
Re: lS1 CONVERSION COOLING QUESTIONS
Post  Marky522 on Thu Jul 07, 2011 6:23 pm
Hey man, great to see another Tech! Im a Porsche tech. Really for the LS motors your stuck buying or building a set. One thing i have noticed recently that you could possibly dig into is the 2010 Camaro manifolds look very promising how they dump straight down so far back, and hug so tight to the block, only question is weather the steering shaft would clear... If you have any questions feel free to PM me and ill send you my Cell!!!
Mark
Marky522
Post  GMMASTERTECH on Fri Jul 08, 2011 1:49 pm
Hey Mark, thanks for getting back to me so quickly, being a gm tech makes the ls1 an easy choice. I like the Camaro exhaust but the G8 pontiac seem to be a contender, it dumps farther back by about an additional 1 3/4 to 2 inches. I would like to use manifolds over headers for the reliablity /durablity issuses and the underhood heat reduction Question . I,m really not sure to do about cooling, which radiator is the best? As a tech we see people do stupid sh*t repeatly and then pay to do it again correctly even aginst our advice. I just don't to repeat that concept.
GMMASTERTECH
Post  87-944S on Fri Jul 08, 2011 4:10 pm
The Porsche Turbo radiator is proven with the LS1. Easy to add to 85.5 and later NAs I have an 87S. Just get a turbo lower radiator mount and it fits in nice. You will need the turbo radiator fan mount as well. All the stock plastic duct work covers it as well.
cooling system with A/c
Post  GMMASTERTECH on Fri Jul 08, 2011 4:21 pm
Thanks Mike , that sounds like the right radiator/fan path, does your 87s have a/c and if so is the condensor and air flow all stock, I have heard nothing but whinnning about keep this conversion cool and just want to play it safe with mine. what if anything do you know about using the stock 944 power steering pump or is the gm Camaro p/s pump the way to go? Shocked
GMMASTERTECH
Post  GMMASTERTECH on Fri Jul 08, 2011 4:25 pm
Hey Mike another passing question for the guru will the cooling fans from the 944 n/a fit the turbo mounts or do I need entire turbo fan/ scroud set up thanks
Benjamin
GMMASTERTECH
Post  Rich L. on Fri Jul 08, 2011 4:26 pm
How can you tell a 944 N/A radiator from the turbo one? My '87 N/A was supposed to have been upgraded to a turbo radiator but I'd like to confirm. Thanks.
On the PS, there used to be an adapter to use the Porsche pump. But I saw reference to the "last one" having already been made and sold. I'd like to go that route, perhaps if there were 2 orders... Wink
Post  expuppy on Fri Jul 08, 2011 6:00 pm
If you are going to spend any time on a track, I would upgrade to the Ron Davis radiator. At 944Fest, a guy had a LS conversion with the turbo radiator on it and it ran hot after a few laps. I had same engine and Ron Davis Radiator and could run 30 minute track sessions and not run hot at all.
expuppy
Post  87-944S on Fri Jul 08, 2011 7:20 pm
You just need the fan housing, the fans from 85.5 on fit.
Post  Admin on Fri Jul 08, 2011 8:45 pm
I have tried every manifold that I can get a hold of , None work without modifications to say the least!
You radiator should have a part number on the top. It will start with 951.---.---.---
you will need the lower mount and the turbo fans.
Post  docwyte on Mon Jul 11, 2011 8:26 am
Turbo radiator works fine on the street. On the track I'm seeing water/oil temps of 250F with it, so I'm going to upgrade to the Ron Davis radiator sometime soon.
Post  Lemming on Mon Jul 11, 2011 9:23 am
docwyte wrote:Turbo radiator works fine on the street. On the track I'm seeing water/oil temps of 250F with it, so I'm going to upgrade to the Ron Davis radiator sometime soon.
So the plan to use my turbo radiator in my track car may be short lived Crying or Very sad
Post  docwyte on Mon Jul 11, 2011 9:43 am
Well, maybe. My car still has the AC condenser and also weighs quite a bit more than yours. Also I'm up at altitude and the thin air isn't doing me any favors as far as cooling.
Try it, but I'd prefer to see cooler temps than I am on track.
Post  xschop on Mon Jul 11, 2011 10:25 am
5% Methanol, 25% Coolant, 70% H20
Post  Lemming on Mon Jul 11, 2011 12:37 pm
xschop wrote:5% Methanol, 25% Coolant, 70% H20
If by coolant you mean antifreeze, that is not allowed in racing.
Lindsey Racing Radiator?
Post  BeaverDeceiver on Thu Apr 23, 2015 12:13 am
Hi I am new to the forum. I too have a 86 944NA putting in a LS1 from a 2001 TransAm. I have read a lot about using a radiator from a Turbo. Lindsey Racing makes a bigger billet radiator with or without a built in oil cooler. I am thinking this is a good option since it upgrades the performance from the already adequate turbo radiator. Thoughts? Has any one used one?
BeaverDeceiver
Post  docwyte on Thu Apr 23, 2015 8:03 am
Much better fitting options out there, like the Wizard or Ron Davis radiator if you're planning on getting away from stock
Post  pormgb on Thu Apr 23, 2015 9:59 am
Buy a set of headers made for the car, not worth the pain and time trying to adapt manifolds or other headers.
I also just upgraded from 2002 Camaro manifolds to headers with dual 2.5" pipes, the performance gains are significant.
pormgb
Post  Rich L. on Fri Apr 24, 2015 12:05 pm
I switched from a turbo radiator to a Wizard and it did not help my overheating issues at all. Then I vented the hood and cooling was much improved. The Wizard is a very tight fit but has all the same mounting points and hose fittings.
That's my $.02.
Post  BeaverDeceiver on Sun Apr 26, 2015 11:21 pm
Rich L. wrote:I switched from a turbo radiator to a Wizard and it did not help my overheating issues at all. Then I vented the hood and cooling was much improved. The Wizard is a very tight fit but has all the same mounting points and hose fittings.
That's my $.02.
I looked at the Ron Davis radiators they all seem to be 2 row 1" tubes as is the Wizard. That is what the Lindsey Racing radiator is and it will fit in an NA 944 although the Wizard is a bit cheaper. Rich when you say tight fit how do you mean. Clearing the engine accessory drives or in the supports? I am also looking to do hood vents. Did you cut your hood or buy a fiberglass one? I am thinking about getting a GT racing fiberglass hood and adding their vents to it. If you have a pic of the vents you have. I'd really like to see it.
BeaverDeceiver
Post  Rich L. on Mon Apr 27, 2015 12:53 am
BeaverDeceiver wrote:Rich when you say tight fit how do you mean. Clearing the engine accessory drives or in the supports?
I mostly mean the supports. The fans go on and space to the f-body accessory drive is reasonable. But getting the radiator in on it's mounts was way more difficult than the stock turbo rad. The Wizard went in, but it's exactly the biggest that would make it in there.
And here are my hood vents.
From the underside of the hood.
Post  jpkinerk on Mon Apr 27, 2015 10:09 pm
I recently swapped out my used Turbo radiator for a new Turbo radiator and the difference was noticable. I never hit higher than about 210F on the street (it was about 75 degrees outside), when I was hitting the typical LS 230F in stop and go traffic before. I'll be hitting the track for the first time at Putnam May 9th, so I'll let you know the verdict. I'm caustiously optimistic at the moment though. Running stock Turbo fans at the moment too. Kind of hard to beat the fitment around my hoses and such, so I'm hoping it works.
jpkinerk
Post  BeaverDeceiver on Sun May 03, 2015 2:15 pm
Thanks Guys I appreciate the insight!
BeaverDeceiver
Post  Tony D59 on Thu Feb 18, 2016 7:52 pm
Do you guys know the model # for the griffin and the rod davis radiators? My car is strictly for the track so trying to do this once...
Tony D59
Post  docwyte on Fri Feb 19, 2016 10:34 am
You get the Ron Davis radiator from Renegade Hybrids. Not sure Ron Davis sells them on their own
