Today at 1:35 pm by kevin924kevin
» New 944 widebody & aero
Yesterday at 5:56 pm by scryfst
Yesterday at 11:23 am by Murrdog9000
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
F-Body PCM already programmed and tuned for a 944 conversion
Post  Arthropraxis on Thu Jun 30, 2011 9:11 pm
I bought a F-body PCM from [You must be registered and logged in to see this link.] and he programmed for the conversion with the correct final drive ratio, manual gearbox, 40 tooth VSS, retain mass airflow and 25 inch rear tires, all of the emissions removed and rear O2 sensors deleted. He does some fuel mapping changes and other tweaking to optimize the performance. The program is not locked, you can still make changes. Check out his website and look at LS1tech.com for his references, he has a great reputation. The PCM is for a red and blue connector, it won't work with my green and blue connector harness without some rewiring so I am going to use the original PCM.
I paid $282. I will sell for $180 + shipping OR Best Offer
Re: F-Body PCM already programmed and tuned for a 944 conversion
Post  Arthropraxis on Wed Oct 12, 2011 9:48 pm
I see several new guys planning conversions. This is plug and play for a Red/blue harness or for a Green/blue with some harness re-wiring.
Post  Bluemach1 on Thu Oct 13, 2011 10:52 am
Can you tell me what he programmed the VIN as? Model vehicle and year. Does it come up as a M/T or an automatic. Did he delete the rear O2's? These are important to know for anyone doing a conversion in California.
Bluemach1
Post  Arthropraxis on Thu Oct 13, 2011 11:29 am
I don't know the vin, it does have a seial number on it, not sure if it helps. The tune is set up for a manual car with all emissions and rear O2 sensors removed. Thanks, for the questions. I didn't think to include that info.
Post  87-944S on Fri Oct 14, 2011 8:55 am
Do you know if the tune is locked?
Post  Arthropraxis on Mon Mar 05, 2012 8:33 pm
The tune is not locked and it is still for sale.
Post  gamman on Mon Mar 05, 2012 9:25 pm
Will this work on a vette PCM? Are the years interswappable? Ie 92-94-95 PCM.
gamman
Post  Arthropraxis on Mon Mar 05, 2012 9:34 pm
I don't think it will work. Those are LT motors this is for a LS.
Post  Arthropraxis on Sun Apr 29, 2012 9:08 pm
Still for sale. This should be plug and play for any conversion. I will sell it for $150 plus shipping and trade for your stock PCM.
