Lowering transmission
Anybody (I know admin has to have done this) lowered their transmissions with spacers for the swap? I know the x-member spacers make the torque tube assembly angle a little for clearance but what about dropping the whole setup an inch or so further? I have an early car so it has the beefy mounts, not the fairy pansy swingset mount the late car comes with. Would axle angles be compromised, would I be risking breaking anything...? Worst I can think of is binding CV joints somehow.
v2rocket- Posts : 121
Re: Lowering transmission
You won't affect anything except you'll have a better COG
You will quickly hit the torsion tube carrier. Also dropping the tranny on a lowered car may lead to cv wear if the angle is to great, so precede carefully.
Today at 9:56 am by ndog52
