Improved PCV system
Improved PCV system
I just wanted to throw a note on here. My '01 LS1 was burning oil because of the PCV system. I removed the old PCV system (thanks to an article that xschop posted) replaced it with the latest and greatest, and it's running MUCH Better!
To upgrade your system to the '04 LS6 PCV setup you need two parts:
12577927 valley cover with PCV system (was $54 at gmpartsdirect.com)
12594779 hose (was $2.37 at gmpartsdirect.com)
Definitely worth the $60 if you're dealing with oil consumption. The install does require cutting a chunk off of the block but it is nothing major. No pictures, sorry
