Question about the manual rack
+11
962porsche
evil
Johnny Johnny
Tetzuoe
15 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Question about the manual rack
arthropaxis i know what you mean . i had one little question . i stalled a dry sump on my car . now with the next 944 v8 i'm building i don't want to do a dry sump system on it just a road racing oil pan . i just did not get why you would change out the rack for an other make .becouse you can get any 944 rack power and manual from rebuilds to new to used . i built my own long run headers to clear the steering shaft . so i was missing some thing ! now i under stand why and don't care why !
962porsche- Posts : 135
Can someone mic the diameter of the passenger side of the MANUAL rack as it passes thru that bushing?
I found an off the shelf POLY bushing for the Driver's side that fits, but can't find a 40mm inner Dia. for the passenger side of my POWER rack.
My caliper says 1.419, close enough to call it 36mm.
I might have to pick up a pair of those.
Your upper strut mount DIY has got me thinking too...
MN944S- Posts : 32
That confirms what I had researched before that the MK1 rack is a rear-steer version of the 944 MANUAL rack and is probably used as a left hand driver (overseas) front-steer rack.....Yes pick a set up, they'll fit our 944 MANUAL racks perfectly. You may need to trim the back for those X-member indentions, not sure, but EASY to do. Thanks for the confirmation again.
Page 3 of 3
Today at 12:47 am by sharkey
