» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
Vibration?? Only when accelerating.
Post  ROGUE S2 on Sun May 29, 2011 10:18 pm
Hey Guys, Would like to get your thoughts on a vibration problem. My car runs great, very happy with its performance. I have put about 4000 miles on it since the conversion. The vibration is at 3000rpm and above only when I'm into the gas really hard. I mainly feel it in my shifter,but you can feel it through out the car. Motor mounts are new and I have an Ultra transmission mount from Lydsey Racing. I am leaning towards maybe torque tube bearings or aluminum fly wheel out of balance? What do you Guru's think. Thanks Shocked
ROGUE S2
Re: Vibration?? Only when accelerating.
Post  Porch on Mon May 30, 2011 2:35 am
Could be a harmonic balancer as well.
Is this new? On the other hand i think that the LS engine has a natural harmonic that gets amplified pretty well in our cars, especially when paired with more solid motor/trans mounts.
Post  pormgb on Mon May 30, 2011 2:49 pm
Hmmm,
I'm having the same problem and was wondering if it my Flywheel/PP out of balance, I'm using an aftermarket balancer. When looking at the motor I don't notice any vibration, when sitting in the car and driving I do notice it, mine feels more like a shudder when revving from around 1500 to 3k rpm it then becomes very light. I'm also using urethane motor mounts with a modified (filled with urethane) tranny mount.
pormgb
Post  pormgb on Wed Jun 29, 2011 8:27 pm
Well, I was preparing to drop my tranny then torque tube, pull out the clutch, PP and flywheel then send them off for balancing.
I just drove the car after a major tune and tightening of my engine mounts, the vibration has pretty much gone. I still get a very light vibration but nothing like before, I still need to get my motor professionally tuned. My logging software shows some fueling issues up to 3K RPM that corresponded with my vibration, the car was running quite lean at high RPMs and rich at low. I think the vibration was my motor rocking back and forth due to its bad state of tune, my loose engine mounts probably amplified the problem. Boy am I relieved. Wink
pormgb
Post  skywalker01 on Thu Jun 30, 2011 5:33 am
Sorry guys - just started reading this thread, but I noticed an increase in vibration when I installed solid transmission mounts - are any of you running with solid tranny mounts?
skywalker01
