Clutch hoses and fittings
+8
Tetzuoe
944v8inDFW
dallas
Johnny Johnny
12 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Clutch hoses and fittings
Right! Thats why I went with the swagelok setup. We use them on lines with 3k on them of steam pressure. The fittings are expensive, it cost me 20 bucks for the setup I used. But I think if you install it at the end of the line where the original flex hose used to attach it won't look too bad and you will save on the length of the flex going all the way to the m/c. And most of all it will be high pressure. As I wrote earlier my earls fitting leaked. I now have no clutch leak and trust it.
dallas- Posts : 69
Well, heres what I have. I went with -3AN everything for quicker clutch action (as the vette guys claim) and am gonna use the aluminum adapter (because I didnt find banjos before I placed the order haha). Ive been running the aluminum adapter that RH (FRH) provided for quite some time and never had a problem with it. I expect the burst pressure of that little fitting to be way more than what im pushing through the clutch system....and I dont believe the whole brake fluid-aluminum thing seeing as most car slaves and masters are aluminum... Everything else is steel. Heres some pics that may help the next guy.
And here it is ready to go in...
Added to the Manual...10/03/09
(Also in the Shopping List)
Thanks MK.
Thanks MK.
gt1scca- Posts : 795
Man MK, you could try to be a little more helpful
Really, awesome job with the pics and info!
RobotMachines- Posts : 165
NNNNNICE! We all like pictures. Good research.
dallas- Posts : 69
Thanks fellers. Still havent hooked it all up to see if it works yet But I have faith.
this is amazing, thank you!
Tetzuoe- Posts : 178
BTW. Where did you find that banjo bolt?? Ive been looking everywhere.
Just search "revtech 662006". Dont search something like "-3AN or -4AN ...." because the "-" sign, in a search string, cancels out the 3AN and 4AN.
Russells and aeroquip also carries them. They are mostly used for motorcycles.
heres one with the 90 degree already built in. [You must be registered and logged in to see this link.]
Got my set.
I bought my fittings based on this thread and they fit the TO bearing and master cyl with no problem. The C5 BH adapter (for those that went that route) needs additional machining to allow the longer/wider fittings to exit the BH without binding on the plate when the TO flange is flush on the surface.
endrnet- Posts : 129
Update: I (literally) bought into this thread and found I had to mod xschops's BH plate a hair. My local machinist charged me $25 for the modification to the plate.
Problem was the hydraulic line nuts were binding / unable to turn since the fittings to go all AN extend the fitting area out further than a stock TO bearing.
Ah! I see. Good tip. I still havent had the chance to fit mine together but will buy the carbide attachment for my dremel before I do.
But everything else okay???
944-LT1 wrote:Ah! I see. Good tip. I still havent had the chance to fit mine together but will buy the carbide attachment for my dremel before I do.
I didn't put up a pic of it mated with the BH but yes, it fit perfectly. Maybe xschop will incorporate into his design if he feels it's worth it, but those of us with "gen 1" BH adapters will need to do this if the fittings in this thread are used.
Page 3 of 3
