December 2019
Quicktime RM-6033
Quicktime RM-6033 Empty Quicktime RM-6033
Post  Outofhand on Sun May 22, 2011 12:39 pm
Has anyone seen this?
Looks like it may make the ls series swaps even easier. Any thoughts?
Outofhand
Quicktime RM-6033 Empty Re: Quicktime RM-6033
Post  Arthropraxis on Sun May 22, 2011 3:58 pm
Several people use one. It is necessary if you need a scatter shield for racing series regulations.
Post  docwyte on Sun May 22, 2011 9:32 pm
That's what I'm using. I wanted it for a few reasons...
#1 It has a scatter shield, and I plan on running at Bonneville at some point and a scatter shield is necessary to run there.
#2 It's a direct bolt in, no need for an adapter plate.
Reason #1 is a personal thing with me, most people don't need a scatter shield, but this is my track car and it's a nice thing to have.
Reason #2 is definitely arguable, but I like as much direct bolt together stuff as possible, it just makes one less thing to fail. Particularly a custom machined part that you can't just find anywhere...
The one thing I do regret about it is it's not a 2 piece design, so access to the clutch still totally sucks and it's not aluminum like the C5 piece, so it probably weighs 15-20 lbs more.
I seem to recall seeing a C5 2 piece aluminum bell housing that comes with an integrated scatter shield. I wasn't aware of it when my swap was happening, if I'd seen it then I probably would've gone with it as it has everything I want except the direct fitment.
Post  95ONE on Sun Jul 31, 2011 12:35 pm
docwyte wrote:That's what I'm using. I wanted it for a few reasons...
Yep Doc.. I agree with it all. DO you know where I can find what you were talking about at the bottom there? 2 piece aluminum/integral scatter?
95ONE
Post  docwyte on Sun Jul 31, 2011 1:54 pm
Check out my thread on rennlist in the 844 Turbo-Turbo S section. I think TonyG lists the part #'s of them.
You'll have to use a custom machined adapter with it though. So you'll get the weight advantage, scatter shield and 2 piece design, but not the direct bolt on...
Post  eclou on Sun Jul 31, 2011 5:34 pm
yeah I'm using that unit as well. Makes everything look factory fresh
eclou
eclou
Post  95ONE on Sun Jul 31, 2011 6:08 pm
eclou wrote:yeah I'm using that unit as well. Makes everything look factory fresh
I might just use this piece. looks simple enough. I found some bad ass used triple plate mcleod clutch for sale. BUT.. I just remembered that the clutch discs need to match ford style spline we have on our drive shaft..... ugh..... ........... I don't want to let that cool part go! lol..
95ONE
Post  xschop on Sun Jul 31, 2011 6:47 pm
Anybody know how deep that BH is from inner TOB seat to engine mating face?
Post  95ONE on Sun Jul 31, 2011 6:57 pm
It also says that you can use a fork to disengage the clutch with this housing.. Anyone use this method?! i don't think I like the current way. more complicated and expensive. Simplicity makes me happy. well, cheaper too.
95ONE
Post  Tim on Wed Dec 05, 2012 6:56 pm
I realize I'm bringing back a super old thread, but what slave cylinder are QuickTime BH users going with? I've done a search and I can't seem to find any info.
Tim
Tim
http://www.OEMPartHaus.com
Post  tecsun on Fri Jan 25, 2013 5:41 pm
I'm with Tim on this, sorry for bringing up an old thread but the info still doesn't seem to be out there. I just got a QuickTime BH and am trying to figure out the slave/TO bearing setup everyone is using. Thanks for any info you guys have.
tecsun
Post  Admin on Fri Jan 25, 2013 8:13 pm
You have to use a bearing retainer from a T10 transmission and then you can use the RAM throw out bearing.
Post  tecsun on Mon Feb 04, 2013 10:07 am
Thanks for the info! Parts ordered. On a side note, I put the engine in just to test fit everything over the weekend and it all fits perfect! My hat is off to Eric for making some awesome parts, I took pics and am going to start a build thread pretty soon.
tecsun
Post  jerome12 on Sat Nov 23, 2019 8:16 am
Admin wrote:You have to use a bearing retainer from a T10 transmission and then you can use the RAM throw out bearing.
Do you have part numbers for the retainer and throw-out bearing?
jerome12
