» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
cross member broken bolt
Post  Tehone on Sun May 15, 2011 10:31 pm
Have a challenge any suggestions. After 20+ years I had a cross-member bolt refuse to let go and stayed in the frame rail Sad .
I was thinking after removing all the wiring, lines, and other items I would cut a window in the side of the frame rail (smudge mark area) to get to the top of the bolt and give it a good soak and try a stud remover if enough is protruding. Any other thoughts.
Tehone
Re: cross member broken bolt
Post  robstah on Mon May 16, 2011 1:38 am
You could just drill it out and try and re-tap for the same size or drill and re-tap larger and run a larger bolt.
Post  944-LT1 on Mon May 16, 2011 2:29 am
Buy a good 12mm (or whatever size thats closest to the inner diameter of that hole) drill bit and get the bolt to concave a bit. The inner diameter of the bung/spacer (or whatever that thing is called) will act as a guide for the drill bit.
Once it has concavity, you can use a small [~1/4"] drill bit to start a pilot hole and then work your way up to whatever extractor size youre using.
Since its kinda vague...I made a pictar.... yes the arrow and bit orientation is wrong....its late. Laughing
Ohterwise, a welder would get you outta this jam too.
Post  Wild Bill on Tue May 17, 2011 11:12 pm
944-LT1 wrote:Buy a good 12mm (or whatever size thats closest to the inner diameter of that hole) drill bit and get the bolt to concave a bit. The inner diameter of the bung/spacer (or whatever that thing is called) will act as a guide for the drill bit.
That's what I would try first! Try to drill straight so if need be be able to drill to bolt size till you get to nut. That removes cross-member at least and hopefully you can run tap and end up with original threads.
Wild Bill
