» Dual MC Mounting Bracket
Yesterday at 10:02 pm by 948
» LS1 1st start
» Need help! Car won’t start
» Brand new ls3 build
» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
HIGH HP Chromoly AXLES 85.5-up
Page 3 of 3 Previous  1, 2, 3
Re: HIGH HP Chromoly AXLES 85.5-up
Post  Dracer on Wed Aug 06, 2014 10:30 pm
Cool. The chromoly is suppose to be tough as nails. If the axles have stock 944 measurements I would be down with a set. Does the diameter of the axle step down after the splines or stay the same diameter? Got a good line on oem 944 cvs (Lobro)? I'm not totally sold on empi quality...
Thanks xschop
Dracer
Dracer
Post  Sentronix on Tue Aug 12, 2014 2:37 pm
Would you like to make a set of these for my t56 swap?
Sentronix
Post  xschop on Thu Aug 14, 2014 11:56 am
Yes, if you make your outboard Stub axles accept 930 cv's. It is the easiest (least expensive) way to get it done as the C5 diff's tri-lobe CVS are 28 splined so those remain untouched.
Post  Sentronix on Thu Aug 14, 2014 1:46 pm
Can you pm me a phone number to reach you at? Thanks
Sentronix
Post  dand88951 on Tue Apr 28, 2015 7:27 pm
xschop wrote:From now on, I will build the chromoly half-shafts (85.5up cars) and the end-user can choose either Type2 or Type4 CV's. I've had good results from Dan's Performance (Empi Type2) CV's. For our application their "High Performance" CV's are not good as they are loosely machined for high mis-alignment angles of Off-Road vehicles. The 944 suspension angles do not travel that extensively.
Which version of the Dan's Performance Empi type2 CV's work on the 951/968 shafts?  I see multiple listings for Empi Type 2.  What are the Type 4?  I haven't had problems with the axles, but I do go through the CV joints.  I think you mentioned you could get a version with chrome moly races?
Thanks for the posts.
dand88951
Are you still making these?
Post  hickmaster2001 on Sat Oct 03, 2015 10:13 am
I am interested in a set of axles and other item for a LS1 944 conversion. Please let me knw how to contact you.
Thanks!
hickmaster2001
Set axles
Post  Pavka944 on Sat Oct 17, 2015 7:58 am
I am interested the set axles for my swap Lt1:)Send my : [You must be registered and logged in to see this link.]
Pavka944
Pavka944
Post  xschop on Sun Oct 18, 2015 8:44 pm
Sorry for the late reply. I am still making these axles on demand with 7-10 days lead time. My email is [You must be registered and logged in to see this link.]
I am also working on a set of chromoly axles for the 968 transmission for Eric Alanius this week and will be producing them from now on as well. Just PM or email.
Post  944_GASM on Fri Feb 24, 2017 2:26 pm
What would it take to get these on an early 944? Not sure what is actually different, if it's the shaft length, or the splines... Thanks!
944_GASM
Post  xschop on Sat Feb 25, 2017 6:57 am
Take your axle shafts out and measure their axact end to end lengths and count the splines.
