Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
Need a depth dimension on the rack bushing clamp.
Post  grobb284 on Fri May 06, 2011 8:18 am
I have been working on a drawing to mount the 944 steering rack on my frame. This is the preliminary, and will have one or two revisions.
xschop was kind enough to supply me with several dimensions for my mounts for the 944 rack. I am in need of a dimension that is marked "x" on the drawing. It is the depth of the flat from the clamp mating surface on the crossmember. xschop has it as .57, I need it more accurate, as with calipers or depth mics to the flat from the clamp mounting split.
I'm thinking of using (3) 1/4 button heads to replace the raised rib at the bottom of the clamp.
By the way, my hat is off to xschop for his assistance.
I have most of the other dimensions.
Thanks in advance.
grobb284
Re: Need a depth dimension on the rack bushing clamp.
Post  xschop on Fri May 06, 2011 9:52 am
X= 0.57"
I measured to the flat part of the bushing interface. I was curious why the manufacturer Ball-milled below that surface.....Must have been a slow day on the X-member line Sleep
Post  grobb284 on Fri May 06, 2011 10:12 am
I'm thinking perhaps they wanted a radius rather than a corner to reduce stress, and undercut for someplace for the rubber to expand to under compression?
grobb284
Post  xschop on Fri May 06, 2011 10:19 am
The real loads are side-to-side not up and down, but I get your idea.
Did you ever get the VW Poly bushings I posted info on? I had to CNC the center of the passenger side out to fit the larger dia. of the 944 Power Rack....Very Crisp turning now with the Polyurethane bushings.
Post  grobb284 on Fri May 06, 2011 11:59 am
No, I haven't done anything with the bushings. I though perhaps using (before welding) the base and the top clamp to hold the polyurethane. I would probably machine the hole undersize then. Is that what you did? If so, what diameter did you machine the hole to?
What do you think about the idea of using (3) button heads (1/4) instead of the cast rib in the bottom half of the clamp?
grobb284
Post  xschop on Fri May 06, 2011 12:32 pm
I wouldn't worry about it if you are using Poly bushings. Mine didn't have the indentions in the VW bushings anyways. After the clamp is locked down they are not popping out.
