Intake and filter
Intake and filter
I just finished fitting my intake and filter. The filter is huge; it's from a 86 turbo 300zx (KN# RF-1011). I had to cut the inner fender out some where the old air box was for it to fit. It clears the headlight too! The only downside is that you need a 3" pipe. It's the perfect shape for that area and it will suck in cold air from inside the fender!
» k & N filter and intake boot
» Corvette Fuel Filter/Regulator in Stock Fuel Filter Area
» Type of Oil Filter for block?
