Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
Fittings (AN) or (JIC) for LS1 pump, Porsche rack, GM hydroboost?
Page 2 of 2 Previous  1, 2
Re: Fittings (AN) or (JIC) for LS1 pump, Porsche rack, GM hydroboost?
Post  rooster on Wed Jun 13, 2012 11:05 pm
fliermike, I'm sure you are correct and my HB unit is an older one. Pisses me off I asked the yard what model year it was from and they said '04. Of course now I have modified the input shaft and thrown away the mounting plate so I doubt I can return it.
As for my lines, I can get the 11/16th to 6AN fitting and my hydraulic guy said he can braze on a 6AN to the existing 5/8 high pressure fitting. I'll get the M12x1.5 fitting you suggested for the rack and do away with the banjo on the high pressure side. I've got all my low pressure lines taken care of so I should be good.....
Thanks for the help.
rooster
Fittings
Post  fliermike45 on Thu Jun 14, 2012 6:43 am
Hydratech also have the SAE thread to 6AN fittings.
Post  rooster on Thu Jun 14, 2012 10:44 am
fliermike,
Hydratech did have the SAE fittings, you are correct. More importantly they have the "flare inserts" #HBS9106 that drop into the port and allow me to use a none bump tube adaptor. Parts ordered, I hope this does it for P/S lines so I can move on to the next thing. I just want to see this thing run already....
rooster
