» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Will repost later...
Post  Marky522 on Fri Apr 22, 2011 8:24 pm
I will repost once i can completely verify.
Marky522
Re: Will repost later...
Post  Arthropraxis on Fri Apr 22, 2011 8:32 pm
Thanks, that will help a lot. I just got another VDO and adapter that didn't work. Just noticed that is M10X1 the LS1 uses M12X1.5 at the head. Will it still work?
Post  Marky522 on Fri Apr 22, 2011 9:06 pm
see first post
Marky522
Post  robstah on Sat Apr 23, 2011 8:00 pm
Just because it's a VDO does not mean it puts out the same resistance.
Based off of the thread on BFC (http://forums.bimmerforums.com/forum/showthread.php?t=1488399&page=3), the resistance is still in the thousands, which is wrong. Have you verified that this works on your car?
