Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
Speedo questions on a 83
Post  map21 on Sat Apr 16, 2011 4:29 am
So I was browsing the forums and came across this.
Apparently the early 944's pull the speedometer information off the left front wheel vs the transmission.
So my question is have an 83 N/A. Does this mean I do not need to use a VSS kit and sensor or does the engine computer still need some type of signal to tell it the car is moving for proper operation, Idle etc.
map21
Re: Speedo questions on a 83
Post  spence on Sat Apr 16, 2011 7:33 am
The VSS kit has nothing to do with how the stock Porsche picks up its speed signal.
Like you said "the GM engine computer will still need some type of signal to tell the car it's moving for proper operation, Idle". That's all it does; it's just for the GM computer.
Post  v8carreragts on Sat Apr 16, 2011 7:11 pm
Dakota Digital has a converter that you can use along with the hall sensor output on you speedo. The speedo hall sensor doesn't give you a quick enough pulse for the GM VSS. The Dakota Digital converter can multiply the hall signal to work with the VSS.
Post  map21 on Sun Apr 17, 2011 6:10 am
Thanks for the info guys. I'm going to check out both options. Now my big dilemma is figuring out if I can use a corvette DBW TB with my truck harness but thats in the works I should know shortly.
map21
