Today at 1:35 pm by kevin924kevin
» New 944 widebody & aero
Yesterday at 5:56 pm by scryfst
Yesterday at 11:23 am by Murrdog9000
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
Turbo to LS430 adapters
Post  fliermike45 on Tue Mar 29, 2011 3:10 pm
I have a pair of steel adapters that fit Turbo front wheel spindles. They are drilled for 94mm ears, and work with LS 430 Calipers. They were incorrectly supplied by Sloan and I had to get the correct ones from Xschop.
These were designed by Xschop
$100.00, shipping within the USA will be an additional $10.00
Last edited by fliermike45 on Tue Mar 29, 2011 3:39 pm; edited 1 time in total (Reason for editing : Added designer data)
Re: Turbo to LS430 adapters
Post  pkt1213 on Fri Apr 08, 2011 4:07 am
Will these for an 86 turbo?
pkt1213
Adaptors
Post  fliermike45 on Fri Apr 08, 2011 6:24 am
Yes if the distance between the ears where your caliper mounts is 94mm.
Post  xschop on Fri Apr 08, 2011 9:59 am
Those will fit an 86 Turbo, but you need to avoid those spindles/Hubs. They are weak and break at the stub shaft and unless you have a rotor hat for the rear hubs, you would have to turn the hub perimeters to get the Boxster S rotors on, making the thinner hubs even weaker....
Those were the only adapters I built for 87-up Turbo 94mm radial mount spindles to upgrade to the Lexus Calipers and Boxster S rotors. I rode in a 400HP turbo'ed 944 a few days ago with the Lexus/Boxster swap and that is some crazy stopping power when they are boosted. The MO30 brakes are limp in comparison Razz
Post  pkt1213 on Fri Apr 08, 2011 1:49 pm
Thanks for the advise XS.
So in otherwords I need to go to the RX7 control arm swap to late model offset?
pkt1213
Post  xschop on Fri Apr 08, 2011 2:00 pm
You can put late spindles on early cars and control arms. The 86T struts will readily accept the 87-up Turbo spindles, you'll either need to elongate the top strut hole or Have camber plates. You don't need RX7 control arms necessarily unless your B-joints pockets are fried. I can definitely build you a set.
And definitely get those adapters from Mike, I won't build those again.....
Post  pkt1213 on Fri Apr 08, 2011 11:33 pm
Well I can't do anything until congress decides to pay me anyways. Laughing
pkt1213
Post  xschop on Fri Apr 08, 2011 11:50 pm
I've been waiting on my Obamacheck since '08.....Don't hold your breath.... Razz
