Question on rack and pinion with LS1, hydroboost.
+11
marc a
948inVA
eclou
Bluemach1
Vorsche944
grobb284
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Hydroboost
Nice pics, but they don't help.
I need to know the exact connections between the PS Pump, Hydroboost unit and the Steering Rack plus any low pressure return line(s). A schematic would help.
Additionally what are the thread type and size of the Ford HB ports?
Thanks.
Thanks.
Re: Question on rack and pinion with LS1, hydroboost.
I haven't really dug in to my HB install yet, but here is some info I found while researching.
http://classicbroncos.com/forums/showthread.php?t=147997
http://classicbroncos.com/tech/mustang-cobra-hydroboost
http://www.gmfullsize.com/forum/showthread.php?t=156800
948inVA- Posts : 224
Found this diagram I had too.. it's not for a 944 but gives you an idea.
Schematic
Many thanks guys, good handle on how to plumb the system. Mike
marc a wrote:grobb284 wrote:I'm wondering if he was braking at the same time turning, and reducing the effective flow rate at the rack?
I'm guessing not . . . . bad things happen on the track when you turn and brake at the same time Maybe AutoX is different haven't done that.
Uh, no. It's called trail braking. If the car can't do it, that trouble, imho.
I just saw that the 2002 ss came with a factory ps cooler. Hmmm.
Gerry
gamman- Posts : 112
Does the P.S. Fluid reservoir have to be positioned above the Hydroboost for gravity feed?
I would assume gravity feed is necessary as all of the factory systems I've seen are setup with the reservoir above the pump. Here's another good diagram:
Hydroboost
Once again, thanks guys for the diagrams.
One more question: What are the threads (and sizes) of the fittings on a Ford Mustang HB unit?
I want to source AN6 adapters for the pressure lines.
Page 2 of 2 • 1, 2
Page 2 of 2
Today at 9:56 am by ndog52
