Today at 8:39 am by chrenan
» Tpc LS adapter plate
» Headers, headers, HEADERS!
XSchop 1-off LS-V8 install kit
Post  xschop on Sat Mar 26, 2011 7:51 pm
$1225 shipped anywhere in the US-48
I'm selling this as a complete set with the last 944 PS pump conversion kit. You can install any LS series engine including the truck motors (4.8 5.3 6.0) with or without AC using a C5 bellhousing. Comes with C5 adapter plate, Pilot bearing adapter and all hardware along with Texas Performance Concepts LS engine uprights that allow for AC if you choose. Also comes with a V8 specific billet-polyurethane transaxle mount and the X-member has been slot-milled for the setback. The X-member also has been line-bored for a 1" drop with 1" Billet spacers and clearanced for the oil pan on the passenger side steering rack mount as well. The rear control arms need NO spacers. I will include the Longer X-member bolts with the kit as well....I guarantee you'll have no hood clearance issues....
I'm also throwing in a Wilwood 13/16" clutch master upgrade adapter....
And will include a steering shaft lengthening mod, just send me your good steering shaft....
The only thing you need to get is a TPC bump steer kit and modded oil pan....
Re: XSchop 1-off LS-V8 install kit
Post  xschop on Sat Mar 26, 2011 11:19 pm
Very Happy
Post  xschop on Sun Apr 03, 2011 8:02 am
Still for sale..... I'll knock off $100 for local pick-up.. Very Happy
Someone asked, and the custom accessory bracket DOES fit the LS3 driver's side head. You would need an F-body Crank pulley...
Post  Arthropraxis on Sun Apr 03, 2011 8:59 am
Any interest in doing the cross member modification on an exchange basis?
Post  xschop on Sun Apr 03, 2011 9:22 am
After chatting with Mike (fliermike) I would do the next one with only a 3/4" drop and 3/4" billet spacers. On this 1" drop, I had to trim the TPC upright studs all the way down to the locknut for A-arm clearance.The point here is to install the motor without cutting on the hood brace...Mike said his hood would clear with just the throttle body angle trim and 3/4" drop. A person would still need a bump steer kit (TPC) either way..... The shipping would be a hassle, but if I were sent a pre-paid UPS boxed X-member that would be the way to go and would only charge $250 for the mod and billet X-member spacers
Post  Van on Tue Apr 12, 2011 4:19 pm
Presumably you also put a 1" bump steer kit on that? (Is that the amount you're relocating the control arm?)
Van
Post  Van on Tue Apr 12, 2011 4:20 pm
xschop wrote: A person would still need a bump steer kit (TPC) either way.....
I should read first, type second! Very Happy
Van
Post  xschop on Tue Apr 12, 2011 4:34 pm
Allen said you were going to build his car. Yes a TPC bump steer kit would be needed IF the 968 hood doesn't clear the trimmed throttle body. Either way, you'll also get a lower COG if you drop the engine down an inch. The TPC oil pan will get you maximum engine drop too with these uprights. He said he's doing hydroboost too so talk with Admin. He suggests 2004 Mustang hydroboost and has built other's 948's here with it and they are happy.
Post  modenas on Tue Apr 12, 2011 7:01 pm
does it come with c5 bellhousing? your wording messin with my head
modenas
Post  xschop on Tue Apr 12, 2011 8:07 pm
No, it doesn't and it is .....SOLD
Post  piperporsche180944 on Mon Jun 06, 2011 10:32 pm
Sold, what a bummer. Seeing the price of the conversion Im tempted to toss a LSX in the P car!
piperporsche180944
