» 83' Porsche 944 LM7 Build
Yesterday at 1:39 pm by Jchard944
» Throttle body question
Yesterday at 12:02 pm by Rothaus
» Oil Pan question
Yesterday at 11:58 am by Rothaus
» Posche 924 Audi 4.2 V8 ABZ
Yesterday at 11:25 am by Ralphhh
Yesterday at 10:04 am by kevin924kevin
Sun Feb 18, 2018 8:05 pm by 948
» Magnuson supercharged car?
» WTB: LS powered 968
GM LT1 350 with zero hours w/ dry sump system
Post  jhelgesen on Thu Mar 24, 2011 12:21 pm
GM LT1 350 with zero hours on build. Ready to install. Needs oil pan for your application.
Parts installed include.
Peterson 3 stage R4 dry sump
edlebrock lt4 intake
30lb bosch injectors
Comp EFI cam
Comp Cam steel roller rocker
Aluminum heads - GM
Meizer electric water pump
58 mm Throttle body
New optispark
ARP studs and hardware
Chrome valve covers
MSD ignition wires
Clevitt nascar bearings
Balanced and polished GM crank
PM or email [You must be registered and logged in to see this link.] for more info.
jhelgesen
http://www.stahlwerks.com
Re: GM LT1 350 with zero hours w/ dry sump system
Post  laptop_geek on Thu Mar 24, 2011 10:48 pm
Beautiful motor. WHY WHERE YOU NOT HERE LAST YEAR!!!!
laptop_geek
Post  jhelgesen on Fri Mar 25, 2011 6:37 am
I can package this with a complete conversion kit too.
SPEC lightweight flywheel and stage 3 clutch
quick time bell housing
lt1 conversion wire harness
custom headers
motor mounts
etc.
jhelgesen
Post  jhelgesen on Fri Mar 25, 2011 8:45 pm
I can also supply the motor as a wet sump motor, replacing the dry sump with a melling HD oil pump.
I have everything you need to install in your 944.
jhelgesen
