Bellhousing
Bellhousing
So, what is the bellhousing of choice the 2 piece or the 1 piece. I have a chap up here in Canada that has a 1 piece from 1999 coupe. He is asking 150.00 for bellhousing, pressure plate and clutch. Is this a good buy or should i find a 2 piece. Please feel free to through you 2c in. thanks.
kevin924kevin- Posts : 927
Re: Bellhousing
kevin924kevin wrote:So, what is the bellhousing of choice the 2 piece or the 1 piece. I have a chap up here in Canada that has a 1 piece from 1999 coupe. He is asking 150.00 for bellhousing, pressure plate and clutch. Is this a good buy or should i find a 2 piece. Please feel free to through you 2c in. thanks.
What clutch set up are you using? That will be the main deciding factor. You can use up to a 10.5" clutch in the automatic (1 piece) bellhousing, and a 11" clutch (maybe more) in the manual bellhousing (2 piece). Not sure of the current conversions to CAD, but I bought a very nice used 1 piece for ~ $90 and a 2 piece for $150.
If you want a 1 piece that is in great shape and already has the cut outs for the HTOB I'll sell you mine for what I've got in it ($90 + shipping to Canada).
laptop_geek- Posts : 230
Re: Bellhousing
The 2 pieces can be had if you look in the right places. The 1 pieces need a clutch setup that will fit, which will be smaller than your standard LSx setups.
robstah- Posts : 352
Re: Bellhousing
the 2 piece is nice for the inspection aspect of the components and u have more acessibility when doing the install i found mine on corvette forum
stu wright- Posts : 312
clutch
Thanks all, according to the chap this is a one piece manual bellhousing comes with disk/pressue plate, etc.Any thoughts?
