» Tpc LS adapter plate
» Headers, headers, HEADERS!
Newb ? - Is/Can ABS be maintained with the swap
Post  roamer on Sun Mar 20, 2011 2:34 pm
I apologize, I tried searching, but to no avail. I am looking to do the swap and a major consideration is being able to maintain abs in a factory-equipped donor. With the modification to the master cylinder and power booster, can the system continue to operate? I recall reading about electronic boosters, which I assume would be necessary to ensure proper operation of the system.
Any insight or referrals would be greatly appreciated!
Thanks in advance.
roamer
Re: Newb ? - Is/Can ABS be maintained with the swap
Post  Dawgz83948 on Sun Mar 20, 2011 9:00 pm
roamer wrote:I apologize, I tried searching, but to no avail. I am looking to do the swap and a major consideration is being able to maintain abs in a factory-equipped donor. With the modification to the master cylinder and power booster, can the system continue to operate? I recall reading about electronic boosters, which I assume would be necessary to ensure proper operation of the system.
Thanks in advance.
Mine still works. Even the cruise works. They are a totally seperate system.
Post  roamer on Mon Mar 21, 2011 8:31 am
Thanks. So, just so I am clear, you are running an un-boosted system and your abs continues to function?
roamer
Post  Admin on Mon Mar 21, 2011 11:02 am
Your ABS will work with or without the boost, Unless you remove it or the electrical power to it.
Post  roamer on Mon Mar 21, 2011 11:35 am
Got it, thanks guys!
roamer
Post  Porch on Mon Mar 21, 2011 12:15 pm
HOWEVER - I disabled mine because I (and a few others) run a larger tire in the rear. You can only have a 1-2% difference between the front and rear tire size. In my case the rear tires are something like 5-6% larger.
It's really a question of how you're going to be driving it. Personally i think the the larger tires (285/35) make the car much more driveable on a daily basis, and the help a little on the freeway too. If this is a track car then the ABS may be more useful to you.
Post  roamer on Mon Mar 21, 2011 5:58 pm
Thanks Porch, so the system uses speed differences to determine allocation of braking force rather than simply responding after a lockup (a good thing).
roamer
