» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Pulled LS1 Engine and Engine Harness. What else do I need?
Post  johntorg on Sun Mar 20, 2011 6:57 am
I Pulled LS1 Engine and Engine Harness and was wondering what else I need from the 2000 Camaro donor car? I also pulled the battery cables. Do I need the fuse box or any relay setup?
johntorg
Re: Pulled LS1 Engine and Engine Harness. What else do I need?
Post  spence on Sun Mar 20, 2011 7:13 am
When I wired my car I re-used the stock camaro fuel pump relay and the fuse box from the camaro. It all depends on how your planning on wiring your car I guess (pre-made harness vs. self wired).
Post  944-LT1 on Sun Mar 20, 2011 7:44 am
If you have the means, and its relatively cheap or even free, take all you can. Especially anything electrical. Id also grab the radiator hoses to help with mock-up.
Post  johntorg on Sun Mar 20, 2011 8:55 am
Thanks for the advice. I have pretty much the whole car, so I'll pull what I can.
johntorg
Post  Bluemach1 on Sun Mar 20, 2011 1:19 pm
grab the ALDL plug from under the dash and if you are going to run AC, grab as much of that plumbing stuff.
Bluemach1
Post  johntorg on Sun Mar 20, 2011 5:31 pm
What is the ALDL plug?
johntorg
Post  Admin on Sun Mar 20, 2011 5:35 pm
The Data plug, should be under the dash of the car, you'll have to have for any computer service type work
Post  johntorg on Sun Mar 20, 2011 6:18 pm
That's what I suspected. I always called it the OBDII connector. I assume there's a cable the runs to the LS1 engine harness.
johntorg
Post  Admin on Sun Mar 20, 2011 7:45 pm
This is , but there is not! The wires that connect to it seem to join into the dash harness. There isn't a direct connect to it. I just cut it with as much wire as you can get. You will have to make your own connection to the ECU anyway.
