Vibration in Gear Shift Lever
I get a quite noticeable vibration in my gear shift lever that increases and seems to peak at about 2800-2900 rpms.
It vibrates like that no matter what - at any speed including stopped still, in gear or out, clutch in or out, my gear shift buzzes like an angry hornet at about 2800-2900 rpms.
I'm assuming something's out of balance with the clutch, pressure plate and/or fly wheel.
Any other ideas?
Any other ideas?
acorad- Posts : 697
Re: Vibration in Gear Shift Lever
Was it doing it the first time you drove it after the swap/start-up?
Yes.xschop wrote:Was it doing it the first time you drove it after the swap/start-up?
acorad- Posts : 697
Did you ensure the TT shaft splines were fully engaged with the clutch disc and that the 15mm (dia.) shaft tip inserted into the pilot bearing fully?
Well...I will when I pull the clutch, which should be fairly soon...
acorad- Posts : 697
Hope you didn't suffer the same demise as DVC and others. If you can please post the actual spline length and brand/part# clutch disc you are running.
Yeah, me too.
How about this, pretend we didn't just spend three pages on DVC's spline problem and that his problem's not on the table, what would be your next best diagnosis based on the symptoms I outlined before I pull the whole thing apart?
acorad- Posts : 697
Sucks, but this sounds just like shaft tip non insertion, so the disc is oscillating all over the place. Don't drive it till you know 100%.....
If you have my adapter plate and 1.00" PB adapter (LS swap) you can set your TT shaft to TT relationship this exact dimension (5.17") and use a 15x35x14 Pilot bearing (diregard the blue-spacer).....Then lock the rear coupler down....
I haven't crawled under to take a look at mine, can you see enough with the inspection plate off to tell if you have enough engagement?
Ugh, thanks, it'll be a couple weeks probably before I'm able to get into it.xschop wrote: Sucks, but this sounds just like shaft tip non insertion, so the disc is oscillating all over the place. Don't drive it till you know 100%.....
acorad- Posts : 697
Shaft tip insertion has to be viewed with the clutch PP and disc removed. OR you can use the diagram and cheat off me....The mic doesn't lie.
EDIT: Actually I always wondered if the 2.63" dimensions were all the same on the 944 TT's. If this is true then the clutch disc and PP can stay put and the relationship measured from the base of the TO bearing/TT adapter seat to the start of the splining (1.925").....FYI
I have a spare TT in the garage I can measure the 2.63 dimension this weekend. I wonder if you can measue the end of shaft to the housing that attaches to the transaxle to determine if it fully seated at the flywheel. I'm replacing the transaxle before it hits the road, so that dim would be helpful.
You've probably already seen it, but there's a spline pictured next to a tape measure on DVC's "Wore out my driveshaft" thread that looks like it measuires a hair over 2-5/8".xschop wrote:Shaft tip insertion has to be viewed with the clutch PP and disc removed. OR you can use the diagram and cheat off me....The mic doesn't lie.
acorad- Posts : 697
Today at 12:47 am by sharkey
