» Tpc LS adapter plate
» Headers, headers, HEADERS!
Oil cooler and temp gauge examples
Post  Dan J on Fri Mar 11, 2011 3:52 pm
Hi,
I'm planning to add an oil cooler setup before the summer. Does anyone have pictures handy of their oil cooler/temp setup? I've mounted the remote filter up behind the driver's side foglight, which seems conventional. Am thinking of mounting a cooler somewhere either to the side or just in front of the lower radiator. I'm also thinking to mount an oil temp sensor somewhere in-line.
Thank you in advance for sharing.
Dan.
Dan J
Re: Oil cooler and temp gauge examples
Post  a951 on Fri Mar 11, 2011 5:11 pm
my approach to it. not done, but looks like mounting the oil filter, in the room behind headlight you see, and under filter, then have the thermostat under it.
a951
Post  Dan J on Fri Mar 11, 2011 6:58 pm
Makes sense. I have my air cleaner under the header panel though.
I'll have a look this weekend and try finding a place for a small cooler. There's lots of room, I'd just like to find a place that's relatively straightforward for routing hoses and such.
Thanks for the idea.
Dan.
Dan J
