944 Track car
+2
jhelgesen
6 posters
944 Track car
Not much left of the original car except the body, and some of it will go eventually.
Started life as an 85 na, now sporting turbo suspension with escort cup Bilsteins, turbo LSD tranny, LT1 with lots of go fast goodies, dry sump, full cage, etc.
After a year + hiatus, she's getting back on board.
Re: 944 Track car
Looks great! Very nice work. Bet it's a lot of fun
Re: 944 Track car
Still making progress.
Headers are fabricated, y pipe fitting is next, then off to tig them up.
Oil pan is coming out again to relocated the dry sump fittings. I was also able to rotate the starter on the mount to gain more clearance....
Re: 944 Track car
Glad to see your back doing this project. Good luck!
laptop_geek- Posts : 230
Re: 944 Track car
Cleaned off the firewall tonight to make room..
Cut out the pedals and the area over them
Then test fit my new pedal assembly
Re: 944 Track car
Headers are almost done. Just came back from being TIG welded. Next to trim to length and install collectors, then off to be JET coated...
Re: 944 Track car
I was reading through your post and you said that you are going to make a "Y" pipe next, now that the headers are done. Why are you gong with a single exhaust after all the hard work of making the long tube headers? Why not go with duals?
Headers look good. I hope mine come out that nice, Are those your first set that you made?
Re: 944 Track car
headers look great! What material did you use and how did you bend them?
Re: 944 Track car
Thanks for the compliments. This is my first set fabricated, but I had a very experienced buddy helping out who also did all the TIG work. Y pipe is 3" and will be all the way to the back of the car. The 3" rear half is already there and should be adequate. I may change to duals in the future if it makes a performance improvement.
Tubing is steel welded seam (we didn't need DOM for exhaust, save that for our cages), some tubes bent on our tube bender, some are off the shelf.
We've got another set in the works for a 383 track car and then another LS project.
Re: 944 Track car
Finished work on the buddies car, installed these headers that we built for him.
Back to work on my car. Modifying the oil pan again to fit the dry sump lines between the starter and cross member....
headers,
Very nice job on those units. What are the pros and cons, long tube/short tube. are you running a traditional collector flange or the v bands.
kevin924kevin- Posts : 927
Re: 944 Track car
OT, but it looks like the right side of most of the pics is cut off on this and many threaqds, is there a way to see the whole pic?
acorad- Posts : 697
Re: 944 Track car
acorad wrote:OT, but it looks like the right side of most of the pics is cut off on this and many threaqds, is there a way to see the whole pic?
a) If your using Firefox just right click and select "View Image".
b) If your not using Firefox, download this, then refer back to a.
Re: 944 Track car
laptop, there was no link to a download, I'll try firefox
acorad- Posts : 697
Re: 944 Track car
acorad wrote:laptop, there was no link to a download, I'll try firefox
Click on the "download this" section. It will bring up the main page for firefox (http://www.mozilla.com). There is a link there but the forum kinda hides it.
Re: 944 Track car
Ah, got it. Thanks!laptop_geek wrote:acorad wrote:laptop, there was no link to a download, I'll try firefox
acorad- Posts : 697
Re: 944 Track car
If I change to color to blue (put color=blue into [brackets]) then I get the following result.
laptop_geek wrote:acorad wrote:OT, but it looks like the right side of most of the pics is cut off on this and many threaqds, is there a way to see the whole pic?
Re: 944 Track car
No problem!
Re: 944 Track car
kevin924kevin wrote:Very nice job on those units. What are the pros and cons, long tube/short tube. are you running a traditional collector flange or the v bands.
Best of my recollection longer tubes get you torque at a lower peak rpm. We're running traditional collectors, 4-1.
» 944 V8 representing at open road race in 2012
» 944 ls track car
» Building a LS1 968 track day project car
» 944 ls track car
