944Hybrids
Welcome to our forum.
» Pacific Raceways near Seattle
Today at 7:26 am by Lemming
» HELP . . . Electrical gremlin
Today at 12:01 am by Rich L.
» Rich's LS powered 944 track car
Yesterday at 8:59 pm by Lemming
» First Time Swap 85 Porsche 944 to LS6
Yesterday at 7:03 pm by kjducati
» Oil and steering cooler options
Yesterday at 6:11 pm by docwyte
» selling conversion parts due to new baby
Yesterday at 4:29 pm by zeusrotty
» Strut brace?
Mon May 14, 2012 5:38 pm by fliermike45
Mon May 14, 2012 1:56 pm by epsylon9mm
» building a 1983 948 on a budget - pointers?
Mon May 14, 2012 7:19 am by Admin
» To " badge or not to badge "
Sun May 13, 2012 5:01 pm by 944-LT1
May 2012
78910111213
14151617181920
21222324252627
28293031
tach wire hookup options
Post  golfduke on Tue Jun 09, 2009 10:53 am
q. What wire, on the back of the tachometer, should the tach output run to?
A. 85.5 and later is the green wire with thin black stripe.
Also-
The tach wire is the Red/Blue wire on pin 2 of the T1 connector (in pasenger footwell). Do not confuse this with the Red/Blue wire on the t21 connector (it is for fuel injectors).
I connected the Red/Blue wire to C105-G from my LS1 and the tach works perfect.
golfduke
Re: tach wire hookup options
Post  endrnet on Mon Apr 19, 2010 6:16 pm
Which of these is T1?
Also, neither one has red/blue or green black in the pin2 position. The lower one has a green/black but it's in pin 7 I think.
endrnet
Post  modenas on Mon Apr 19, 2010 10:12 pm
endrnet dont you have a S? if so that explain the extra 14 pin and we can tell you what it is
modenas
Post  endrnet on Mon Apr 19, 2010 10:19 pm
Don't think so, no "S" badge.
endrnet
Post  modenas on Wed Apr 21, 2010 1:04 am
If i remember right, I was told to use the blue and green or green and white. cant remember which one. have to look it up on the fourm.
ok so here the edit,
searched and this is what i found
http://944hybrids.forumotion.com/lsx-conversions-f3/lsx-tach-hook-up-t138.htm?highlight=tach
Last edited by modenas on Wed Apr 21, 2010 1:07 am; edited 1 time in total (Reason for editing : update, new info)
modenas
Post  robstah on Sun May 01, 2011 2:57 am
Just to document this somewhere, I was looking for the CEL wire from the DME (seems non-existent) and found the red 4 pin plug. This is where that green and black wire comes in. To my understanding, the connector grew in size when going to the 16v motors, so keep that in mind. This wiring diagram is based off of an '86 turbo.
This is the connector I yanked from the stock engine harness. The green and black wire connects to the PCM tach wire. Removing the other pins is very easy with this connector.
