Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
5th gear options, Audi?
Page 4 of 4 Previous  1, 2, 3, 4
Re: 5th gear options, Audi?
Post  Rich L. on Fri Jun 15, 2012 1:32 pm
Mike, that's very odd. So, using this website:
http://www.kabamus.com/garage/gears.html
3k rpm w/ .83 5th would result in 69 mph
3k rpm w/ .73 5th would result in 79 mph
I'll test mine next chance I get, still the stock '87 944 na trans.
Gear ratios
Post  fliermike45 on Sat Jun 16, 2012 4:10 pm
I never counted the teeth either.
Will do a 3000 rpm check.
What does ROW mean?
Post  87-944S on Sat Jun 16, 2012 8:35 pm
It should mean rest of the world, Porsche used that a lot in describing models.
ROW
Post  fliermike45 on Sun Jun 17, 2012 7:55 am
How do I find out if my car is ROW? Does the VIN # hold a clue?
5th
Post  fliermike45 on Mon Jun 18, 2012 2:43 pm
Quoting from a 944HYBRIDS post made by Marc A:
"The early (pre 1985.5) 944 NA 5th gear is lower numerically than the 944 Turbo and 944S transaxle 5th gear ratios. (.73 vs .83)"
This would explain why my 88 NA owner's manual states that the 5th gear is .83
My Turbo trans has a 5R code and according to sloan's book had a stock .83 5th gear.
Guess I wasted my time swapping the 5th gears except I did fit a stiffening plate.
Here is the gear Iremoved from the Turbo Trans.
Last edited by fliermike45 on Mon Jun 18, 2012 2:57 pm; edited 2 times in total (Reason for editing : typo and pic)
NA 5th
Post  fliermike45 on Mon Jun 18, 2012 6:14 pm
The buyer of my old NA transmission just called with the data.
It was built in 87 and is a 5Y type 16J and according to sloan's book a ROW W/O LSD.
This confirm's my suspicions that I now have a .83 fifth gear.
Post  acorad on Mon Jun 18, 2012 6:36 pm
Glad you figured it out!
The little gear in your pic above has 29 teeth, so that's for sure the 35:29 (0.83) gear set, as it should be since it came out of a Turbo trans.
Post  acorad on Mon Feb 09, 2015 6:12 pm
So I just discovered that my speedo is reading 8-10 mph low, so I am running about 2250 rpm at 70 mph with the 0.68 Audi 5th gear, which is exactly what I was wanting! Luckily I discovered the speedo error before I got a speeding ticket...
Post  xschop on Tue Feb 10, 2015 7:59 am
That's good news....just as gas is creeping back up.
Post  AZBanks on Wed Feb 25, 2015 1:38 pm
Hi, I haven't posted enough to be allowed to send PM's. I would like a copy of the paper you wrote if it is still available.
v8carreragts wrote:Unfortunately these thoughts don't work. The only gear that can be swapped is 5th gear. Third and fourth on the AUDI is press fit and the turbo/S/S2 use splines (one reason they are stronger). First gear is part of the input shaft and the input shaft is not swapable. The front end is too short and has a smaller diameter which requires a different case. (the case has smaller diameter input needle bearings) The AUDI input shaft is also .15" shorter between 2nd and 3rd gear along with the shift shafts and pinion. The AUDI case isn't machined for the turbo/S/S2 ring gear (the ring gear is slightly larger in diameter than the AUDI) and it uses a much larger bearing on the pinion ring gear end. The AUDI case doesn't swap with the Porsche case without a lot of specialty machining.
I wrote a paper comparing the G31, 016 and the 944 turbo/S/S2 (which is an 083 not an 016) and it has a lot of information about the differences between the 016/083. It also has some info on the 01E. It is in WORD format (.doc) and .pdf so I would need to e-mail it to anyone interested in a copy.
AZBanks
Post  pa951 on Mon Mar 30, 2015 2:51 pm
acorad wrote:So I just discovered that my speedo is reading 8-10 mph low, so I am running about 2250 rpm at 70 mph with the 0.68 Audi 5th gear, which is exactly what I was wanting! Luckily I discovered the speedo error before I got a speeding ticket...
What gear is this? We want to upgrade my european 951s gearbox so the cruising rpm in five would be low like yours. But can't really find the gear you used.
Maybe i did not search enough or it is not mentioned. Embarassed
pa951
Post  acorad on Mon Mar 30, 2015 3:08 pm
No worries: http://944hybrids.forumotion.com/t1190p15-5th-gear-options-audi#13514
"fyi, from my research: the swappable 0.68 5th gear is in '80-'82 Audi 5000 Diesels w/trans codes: UF, MN, BMO, WV, UW, MO, MR, AAW, AAV, AAY, AAX, AMM, & AMN.
edit: And from my research, the 0.68 is the tallest USA spec gear available."
Andy
Post  pa951 on Mon Mar 30, 2015 3:18 pm
Thanks. study
pa951
Possible .68 Audi 5th gear set supplier
Post  AZBanks on Fri Apr 24, 2015 9:38 pm
I may have a supplier for the Audi .68 5th gear sets.
They are Audi NOS
What would people pay for these gear sets?
AZBanks
Post  AZBanks on Tue Apr 28, 2015 9:32 am
I still don't have enough posts to send or reply to a PM.
I should know how many gear sets will be available in the next day or so.
The price will be in the $300 to $500 range.
AZBanks
Post  AZBanks on Tue Apr 28, 2015 3:51 pm
I just got word back that the gears are NOT available and their website was in error.
My order is cancelled and they have NONE available.
I am so extremely pissed!!!!!!!
Sorry to get everyone's hopes up. Back to searching junk yards.
AZBanks
Post  944_GASM on Tue Mar 22, 2016 12:37 pm
Reviving this from the dead.... But has anyone has issues with the N/A 5th gear swap into the turbo box? I was talking with Kevin Gross about doing a rebuild on my AOR with my early N/A 5th but he had the following to say:
"I agree that the AOR gearbox, with its stronger input shaft (esp. 1st and 2nd gears as cast into it) and LSD is the best route. Unless you are certain of its service history, I also agree that a rebuild and fresh fluid are important.
Fifth gear in your NA transmission (37:27) is a little taller than the 944 Turbo fifth (35:29) and a taller 5th is often seen as a good option for LSx transplants. However, keep in mind that fifth gear and the input shaft bearing next to it get lubrication differently and there may be an issue – emphasis on “may be” because I am not certain. Going the other way (late 5th in early gearbox) definitely starves the rear of the input shaft of lubrication and I have seen the damage from trying this. But in your direction, there are in fact two paths lubricating 5th (from the end of input shaft via hollow bolt, plus through two bore holes in fifth gear) which may be fine, or maybe not if the bore holes bleed off oil before it flows to the 016-311-427-C bearing in the end plate (steel center section). A more conservative choice would be to use the taller 5th gear from the 944S2 (36:28), but it is not quite as tall as the 944 NA.
(I looked into plugging the bore holes for a client about a year ago, similar issue. The path to do that would be to have a cryogenics shop drop pins into the bores, and I have one will to do the effort. The gear itself has been hardened to a Rockwell number usually seen on tools, and machine it for threaded plugs would be prohibitively expensive, requiring diamond drill equipment. This is the short summary of what I learned visiting a number of specialist machine shops, etc.)"
944_GASM
trans out of an 86 audi 4000
Post  AZBanks on Tue Mar 22, 2016 1:25 pm
Does anyone know if the 5th gear set out of an 86 audi 4000 will work?
AZBanks
Post  docwyte on Tue Mar 22, 2016 2:10 pm
No idea about the Audi 4000 gears but I've had no issues with my NA 5th gear swap.  In fact Chris Cervelli did the swap and he didn't mention any issues with it and he's the 944 whisperer...
Post  AZBanks on Tue Mar 22, 2016 2:13 pm
How many miles do you have on your NA swap now?
AZBanks
Post  docwyte on Tue Mar 22, 2016 2:19 pm
Not sure but thousands of miles along with hours of track time
Post  944_GASM on Tue Mar 22, 2016 2:35 pm
docwyte wrote:No idea about the Audi 4000 gears but I've had no issues with my NA 5th gear swap.  In fact Chris Cervelli did the swap and he didn't mention any issues with it and he's the 944 whisperer...
That's what I thought - but I needed some reassurance. Thanks.
944_GASM
