Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
5th gear options, Audi?
Page 3 of 4 Previous  1, 2, 3, 4  Next
Re: 5th gear options, Audi?
Post  the951racer on Tue Mar 20, 2012 5:28 am
Oh ok. I got ya. I may be getting the 944 na gear from a guy this week. Just waiting to see what condition it's in since the vehicle was in a head on collision.
the951racer
.68 Gear
Post  fliermike45 on Tue Mar 20, 2012 7:34 am
Acorad,
Where did you get your .68 gear from?
Mike
Post  acorad on Tue Mar 20, 2012 8:48 am
Mike, from my research: the swappable 0.68 5th gear is in '80-'82 Audi 5000 Diesels w/trans codes: UF, MN, BMO, WV, UW, MO, MR, AAW, AAV, AAY, AAX, AMM, & AMN.
I saw more of these boxes at either All Auto Recycling (719) 683-9600 or Jerry's Foriegn (408) 993-9711, both up in the NW somewhere.
iirc, I found the boxes pretty easily through car-parts.net and then called the guys and had them check the trans codes.
Audi box
Post  fliermike45 on Tue Mar 20, 2012 9:19 am
Did you buy a complete box or have them strip out the 5th gear?
Post  acorad on Tue Mar 20, 2012 10:20 am
Complete box. I thought about having them strip out the gear, but was advised against it by many here. And I'm glad I didn't try to go that route. Stripping out the gear isn't hard, but now that I've done it myself, it really isn't something I'd leave to the junkyard guys. The complete box was about $125 + 50 or so for shipping. Can't wait to get it on the open road!
Post  docwyte on Tue Mar 20, 2012 1:10 pm
719 is the area code for Colorado Springs...
Post  matthewb on Mon May 21, 2012 10:33 am
Did the quatros have the same gearing and would 5th be different because of the shaft extension coming out the back?
matthewb
Post  acorad on Mon May 21, 2012 2:00 pm
matthewb wrote:Did the quatros have the same gearing and would 5th be different because of the shaft extension coming out the back?
If the Quattro box is an 016 box then it should all fit, google around for the info for the Quattro box.
Post  matthewb on Tue May 22, 2012 8:41 am
Where on the Audi transaxles is the code we are looking for and what is the format of the entire code? Is it stamped on the top of the bell housing like the 944's are? I am definitely looking to get a .68 gear for my car. I already have the turbo with the n/a 5th but I run about 2200 at 70 and would like to bump it down a bit. I still have yet to find time to make myself a spreadsheet for this car but I have done it on others so I need to get down to it. I don't suppose anyone has any European contacts that could get he even taller gears??
matthewb
Post  acorad on Thu Jun 14, 2012 12:43 pm
Well, just to finish this up, the car is back together and the Audi diesel 5th gear gives me 2500 rpm at 70mph, vs the oem turbo 5th that was giving me about 3000 at 70mph.
Which makes me think the Audi gear I got is the same .73 that the 944 NA has. ([edit] Looks like the Audi gear is 0.68 after all, it just didn't drop my revs as much as I thought it would.)
Kind of a disappointment as I expected the Audi gear to be .68 and rpm's at 70mph to be in the 2250 range...
[edit 2/9/2015] So I just discovered that my speedo is reading 8-10 mph low, so I am running about 2250 rpm at 70 mph with the 0.68 Audi 5th gear, which is exactly what I was wanting! Luckily I discovered the speedo error before I got a speeding ticket...
Post  matthewb on Thu Jun 14, 2012 12:59 pm
Did you count the teeth?
matthewb
Post  acorad on Thu Jun 14, 2012 1:06 pm
Well, counting teeth in this pic, looks like 40-44 teeth. Why do you ask?
Post  matthewb on Thu Jun 14, 2012 1:10 pm
Because if you count the teeth it will tell you the ratio.
matthewb
Post  acorad on Thu Jun 14, 2012 1:14 pm
OK, what ratio is 40-44 teeth?
Post  matthewb on Thu Jun 14, 2012 1:22 pm
In this configuration it would be 0.909. It looks pretty clear that there is more than a 4 tooth difference between those two gears.
matthewb
Post  acorad on Thu Jun 14, 2012 1:59 pm
I think I get it now, I need to compare the teeth between the two gears in the pic.
Looks like 38:26 to me, which = 0.68. (could possibly be 39:26 or 40:26, but those aren't ratios of any 016 Audi trans that I've been able to find.)
And the NA 0.73 5th is 37:27, which my gears in the pic clearly are not.
So I guess my Audi diesel 5th in the pic IS 0.68.
Just didn't drop my revs by as much as I thought it would...
Post  xschop on Thu Jun 14, 2012 2:11 pm
Aco, That sounds right. I double checked this morning commute. I have the 951 box with NA 5th and spin exactly 2600 RPM at 70mph. My rear tires are taller 285-35-18
Post  acorad on Thu Jun 14, 2012 2:52 pm
Thanks xschop.
5th Gear ratio
Post  fliermike45 on Thu Jun 14, 2012 3:36 pm
I was killing time at the AC shop today, I got out my 944 Owner's Manual (printed 9/87) and was looking at the Power Train data. My car is a 1988 model.
It lists the 5th gear ratio for the 944, 944S and 944 Turbo as 0.829:1
The Axle ratio is 3.889:1 for the 944 and S, 3.375:1 for the Turbo
Did I waste my time changing the fifth gear in my turbo box for the 5th gear from my old NA box?
Post  acorad on Thu Jun 14, 2012 4:21 pm
Turbo 5th is 0.83, NA is 0.73.
Post  Rich L. on Thu Jun 14, 2012 6:19 pm
I'm going with the .78 5th gear from the 944 S2.
Post  subterfuge on Thu Jun 14, 2012 6:46 pm
fliermike45 wrote:I was killing time at the AC shop today, I got out my 944 Owner's Manual (printed 9/87) and was looking at the Power Train data. My car is a 1988 model.
My 88 NA had a shorter 5th gear than previous models. Don't know the #s though.
subterfuge
Post  docwyte on Fri Jun 15, 2012 12:49 am
All the Spec 944 guys are salivating over the short 5th's that we have. I mentioned in passing that I was thinking about putting in the NA 5th and I had 3 guys immediately contact me about my .83 fifth.
I'd like to do the swap, but I have other things I need to attend to first...
Gear ratios
Post  fliermike45 on Fri Jun 15, 2012 7:39 am
Here is the page from my Owners Manual.
Post  acorad on Fri Jun 15, 2012 10:12 am
That's a weird one Mike, according to the Clark's Garage info (http://www.clarks-garage.com/shop-manual/trans-04.htm) the US 944's got the taller 0.73 5th and the US Turbos got the shorter 0.83 5th, but some/all of the ROW 944's got the shorter 0.83. Maybe your manual is for a ROW car or something? Hard to believe out of the 100's of times this swap has been done that no one counted gear teeth and everyone missed that there was zero change in rpms after the swap.
