» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Wire to calipers
Wire to calipers
Post  shwinny on Tue Feb 22, 2011 5:09 pm
Is that wire to the calipers needed. I want to cut it off the harness. And is the an adapter out there for the fuel pump. I want a fitting with a 6an to what ever the internal thread is on the out put of the pump. I just got done simple greening the engine bay and had the cross member hot tanked. Getting it ready to paint and mount the uprights
shwinny
Re: Wire to calipers
Post  944-LT1 on Tue Feb 22, 2011 5:55 pm
No. The wire is a pad wear sensor that illuminates the gauge cluster when the pads get low. Just solder the two wires together and tape them up. If you just cut them and leave them, the light on the cluster will light up.
Post  944-LT1 on Tue Feb 22, 2011 6:24 pm
Not sure which fuel pump you have but the Bosch 044 is inlet 18x1.5 outlet 12x1.5. You will need an 8AN hose not 6AN.
Pegasusracing.com is a great place for metric to AN fittings. They have all the fittings you require.
Post  shwinny on Tue Feb 22, 2011 8:04 pm
The pump is the stock blue one. I will solder those wire together. if you guys know what fitting that is that would be great.
shwinny
Post  shwinny on Thu Feb 24, 2011 7:03 pm
I just ordered the msd 5095 starter and a msd opti and a msd coil. 750$ Nothing is cheep. Is anyone running the msd opti. Is it worth the extra money for it. Does the starter pretty much bolt right up to the c5 bellhousing.
shwinny
Post  Dawgz83948 on Fri Feb 25, 2011 10:20 am
shwinny wrote:I just ordered the msd 5095 starter and a msd opti and a msd coil. 750$ Nothing is cheep. Is anyone running the msd opti. Is it worth the extra money for it. Does the starter pretty much bolt right up to the c5 bellhousing.
I am. After two stock OPTI's (Brand New) that failed within 2 months, I bought the MSD one 3 years ago and have had zero issues since.
