Spec Clutch Package
Spec Clutch Package
I just wanted to post up the Spec Clutch setup I received today from Eric.
I ordered the Aluminum Flywheel, Aluminum Pressure Plate, and the Stage 2 Kevlar Clutch. I have not had the ability to weigh out the individual parts yet, according to the postal scale I used at the Post office this full assembly weighs in at a total of 14lbs less @ 34lbs than the stock setup, @ 48lbs.
I will hopefully obtain an electric scale tonight or tomorrow and get the individual weights for this post. I do like the ability of both the flywheel and the pressure plate to change the steel ring instead of the complete unit.
