» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
An LT1 WILL run on the LS1 PCM and Harness...
Post  gt1scca on Fri Jul 10, 2009 1:35 am
Recently I posted this elsewhere...
"Megasquirt has finally reached out to the "Opti-impaired", sort-of...But without a reluctor ring for the LT1. Guess that's up to me...
You can build an MS system for about what the GM PCM and flash costs. The EDIS-8 (Ford V8) coil pack complete system (including crank sensor) can be bought used or new, and that leaves the reluctor ring, which will bolt onto the face of the LT1 balancer."
I have found a SECOND "OptiCrap" liberation @ [You must be registered and logged in to see this link.] Connection)
Here's an exploded view of all the hardware involved to equip an LT1/LT4 engine with the signals required by the Gen3 LSx PCMs. The 1x cam reluctor bolts to the cam sprocket and is located by the pin on the cam. The cam sensor housing replaces the optispark module. The 24x crank reluctor installs on the crankshaft and is located by the 96-97 LT1 crank key (GM# 12550096). No adjustments. Bolt it all on and it's ready to run.
Installation requires the LS1 PCM, new plug-and-play 24x LT1 engine harness or rework of the original LT1 engine harness using our DIY harness components. Anyone who can tune an LS1 PCM can now tune the LT1/LT4 engines using their preferred LS1 PCM calibration software.
LS1 PCM control, RoadRunner real-time tuning with EFILive, forced induction support, nitrous control, 4L60E/4L80E transmissions, electronic drive-by-wire throttle, and more are now possible on any LT1 or LT4 engine!
[Hell, it makes sense...the wiring colors and circuits carried over to the LSX from the LT...]
HOLY SH8T! Razz
Re: An LT1 WILL run on the LS1 PCM and Harness...
Post  Tetzuoe on Fri Jul 10, 2009 7:56 am
GAH! Get this away from me!!!!
... I told myself I wouldnt (listen to my brother and) install megasquirt until I got the motor running!! Now the mere mention of it is putting a bug up my butt.
this is really cool though, I expect I will begin reading up on it.. (slow friday).
I really want 3.57 to come out, I hear there will be more support for the LS, you CAN also use the LS coil packs by tweaking a delay setting of some kind, I remember reading about this. I think the new version will have better support though (among other things) man.. cant wait...
Tetzuoe
Post  gt1scca on Fri Jul 10, 2009 10:14 am
I have been reading for 3 days...(600+ pages of the "MegaManual" online). The LS uses wasted spark (like the Ford EDIS), but the reluctor wheel is 24T, and machined as part of the crank. That has been the main "drag"...EFILive now makes an SBC / LT 24T "LS" reluctor.
EDIT: Did I say "SBC"...YES! The early small block can be "converted" to run LSX injection / harness and PCM with the '96-'97 Vortec timing cover...
v3.57 will add support for the 24T reluctor, etc.
Yea, awesome setup. BUT, the fact that the LT can be made to run on an LS PCM...I wondered if it could, once I saw the similarities of the harness configurations. My suspicions were correct...
Now I have to decide -
MegaSuirt / EDIS, or LSX harness and PCM / coils. Either way, "Sir OptiCrap" has been banished!
Razz
Post  Tetzuoe on Fri Jul 10, 2009 10:20 am
POOS! Razz
thats freaking awesome tho
Ill just start setting up as if ill go with MS, I have two camaro PCMs collecting dust, figure I can desolder the harness connector and use that to bridge over to MS (all inside the wire/relay case I plan on making)
Tetzuoe
Post  bluehellfire666 on Fri Jul 10, 2009 1:37 pm
i'm not that surprised...brendan at lt1swap.com, the guy who tuned my pcm tuned it to use an ls1 maf, sent me the plug, i wired it in (all the same colors) and it works great as far as i can tell!
bluehellfire666
