New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 28 of 31
Page 28 of 31 • 1 ... 15 ... 27, 28, 29, 30, 31
Re: New convert under way
The bomb.
The bomb.
kevin924kevin- Posts : 927
Tacked up and happy with fitment.
I figured I should out a lower brace. I will install a zinc coated steel riv nut into the frame rail once they arrive.
Looking good
On my master i assume the ports closet to booster are front and the port at the end is the regulated rears single line to back. MY 924 master is different.
L
L
What are using for a fuel tank?
Well i am hoping for a stock solution. My factory metal tank can not be trusted as it cant be cleaned properly.I am waiting on a cost to reproduce my stock tank in alluminum at a local shop. If to costly i will need to source out factory poly tank and do a mount system. I am trying to keep spare tire well.
The poly tanks are way better than the factory metal tanks. I know they can be bought in the states for around $300. There's one on eBay now. I don't know what it takes to get one to you.
As far as an aluminum tank, I would stay away from that unless you can put a bladder in it. The welds are prone to cracking and can leak through porous welds. I had one that came in a Ferrari Bueller kit car that I had welded multiple times. They can be coated internally with gas tank sealer, but even that can cause problems if and when it starts coming loose and plugging fuel lines and stuff.
Well sound advise. I see one on line for 200 US. Getting here is no problem. Sounds like I am going poly or I loose the tire well and do a proper bladdered cell.
Well after thinking. I have ordered a new tank from Auto Atlanta. This is a completely rebuilt like new. I guess in the long run it's worth it to me. Everything is new. Funny building a street legal race car and I am doing a nut and bolt resto. Maybe getting a little carried away but oh well.
kevin924kevin wrote:Well after thinking. I have ordered a new tank from Auto Atlanta. This is a completely rebuilt like new. I guess in the long run it's worth it to me. Everything is new. Funny building a street legal race car and I am doing a nut and bolt resto. Maybe getting a little carried away but oh well.
New steel tank? Carried away was deciding to build a 997 out of a 924.............
Well yes but a practical 997. will hold 2 sets of golf clubs and 2 suit cases. and hopefully put a beatin on my Docs 997 TT , lol. I decided to go with the steel tank because its plug and play. I have my straps and rubbers etc so. Its my own fault my original got to bad to use, so pay the piper. It fits real clean with my trans.
Baby got new shoes.
Baby got new shoes.
Do the 997 quarters cover the tires?
Yes they will cover the tires. It looks cartoonish when your close. Question, my manual for my motor says my maf must be 10 in away from throttle body? If closer what's the issue?
If too close, turbulence from the intake pulses can cause the maf signal to fluctuate. But, in all honesty, I have had the maf right on the throttle body due to clearance restrictions and never really seems to be an issue. My tuner always tells me it not a big deal. He can tune for any fluctuations somehow.
If I have room though, I try to get the maf at least 6" away from the t-body. Ideally, you want the maf in the middle of a straight section. So no tight bend directly before or after the maf. That seems to cause more issues than anything.
Thank you. My intake is dead straight no bends.
That will work great
Well body guy came by yesterday. Spent 3 hours assessing what I want. We decided I need to set the car on the ground then we will finalize the design. Should be heading out end of January to get it done. When it comes back it will be painted and ready to reassemble. After many years this car will finally get to stretch its legs. In the interm continue to assemble and bring to life.
That will be awesome. I'm sure the anticipation is starting to set in as you are getting so much closer.
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 28 of 31
